I hear a loud rattling noise coming from where the exhaust is and i hear a loud banging noise when in 4x4 and turn left my sister took it in the snow and turn sharp left now i cant put it in 4x4 with out hearing loud banging when turning left truck idles low stalls out sometimes and wont go in to reverse right away i have to wait a minute or i hear a grinding noise i know it sounds like a lot is wrong but i want to fix it up and make it a off roading toy what do you think is wrong
When a vibration suddenly starts to happen, it means that something is loosening. Usually it's a panel or a sheet of metal that's vibrating on it's resonant frequency, that's why it goes away with speed, it passed the resonant frequency.
It's very hard to find because you have to be under the car to see it. If you find something you suspect, tighten the screws or put a rubber band on it to test it.
The rattle is likely a loose shield or a bad catalytic converter. As for the loud banging, Have you checked the front U-joints behind the brake rotors. As for the Reverse noise? Auto or stick shift?
