SOURCE: I own a three year
ice maker will not work,i push the handle to get ice it makes a noise like the motor is running .the water works just fine .please any ideas
fan won't start by itself.
SOURCE: LG lrfd22850/lrfc22750 water from door dispenser
Most have a reservoir behind the crisper in the fridge where the water sits between uses and unless there is lots of use usually does not run out of cold.
SOURCE: I have a Maytag MSD2758GE side by side
sounds like you need to replace the adaptive defrost assembly. and yes, it will effect the performance of the fridge. the part number is 12002104 if the first 2 numbers of your serial # is 22; or 61003990 if the 1st 2 numbers of your serial # is 10; or 61005988 if the 1st 2 numbers of your serial # is 17. here is a breakdown showing the location it is # 13 in the picture. hope this helps.
Freezer Back Panel
NOTE: Freezer compartment should now be empty and
walls should be clear of anything that will
obstruct removal of back panel.
1. Loosen screws that mount icemaker to freezer
compartment walls.
2. Pull icemaker gently away from wall of compartment.
As you do so, work fill cup free of fill tube. Unplug
icemaker electrical connector and remove icemaker
from unit.
3. (Pull out Drawer only) Loosen and remove screws
that hold 2 basket glides in place at left and right
sides of compartment.
4. If unit has no icemaker pry with flatblade icemaker
connection cover. Remove cover.
5. Remove hex head screws that hold back panel and
remove panel.
6. Squeeze tabs on ice maker plug to release it from
back panel
Defrost Terminator (Thermostat)
1. Terminator is fastened to evaporator tubing with a
spring clip.
2. Snap terminator off tubing and cut wires to terminator.
3. Remove terminator from unit.
That is word for word.
See parts list diagram here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170924&diagram_id=28480593#d28480593
This may help with screws but the defrost thermostat is item 32 and not shown on the diagram. Once you hav ethe access panel off loof fok the thermostat. It will have 2 wires and tough metal clip on it.
Thanks for choosing FixYa,
Kelly
