I got a new toshiba lap top and installed my printer to the lap top. the printer connects to my lap top and everything. But when I try to print...it does not print and says zero documents pending. HELP PLEASE :)
Re: I got a new toshiba lap top and installed my printer...
Right click on printer and take its properties, and click on advance tab. from there you will see options. spool print documents, kindly select print directly to printer.
THANK YOU!! Ive been trying to find a solution for days and this finally worked. Takes a little longer to print but it works!THANK YOU!! Ive been trying to find a solution for days and this finally worked. Takes a little longer to print but it works!
You can't post conmments that contain an email address.
You need its driver and utility - download them from its official page
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3692888&
The
message "no communication between printer and computer". some times
indicates that the cable you're using is faulty or the port selected is
not the printer port you've connected your printer to.cheers.
Sounds like another Vista Bug, i would check the HP site for this issue and if its under warranty, contact HP. If you have alot of Blue tooth devices hooked up, it may be that its trying to use another device in its place or the signals are getting crossed, im not positive.
Its like when you have to many network drives all hooked up and you plug in a USB device, Windows pops up those anoying bubles saying its detected, but in My computer it doesnt show.
So bassically you have to right click my computer, manage, disk management listed uder storage, right click on the device or drive and change the drive letter to something like " W" or " Z" or anything not in use.
It may be a siomilar case with your bluetooth, youo may have to much stuff connected. Try redoing everything like you have so many other times before, and then limiting how many bluetooth devices you have connected at the same time. see if theres a difference.
