LG 42LC2D 42 in. LCD HDTV Logo
Posted on Apr 16, 2010
Has power but will not turn on. red/blue light is
Has power but will not turn on. red/blue light is off. Is there a reset?
TEXAS TV PARTS
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Apr 16, 2010
 TEXAS TV PARTS
Contributor
Level 1:
New Friend:
Answers
22
Questions
Helped
6796
Points
56
Replace power supply,if no sign of life replace power supply,thanks.
2helpful
2answers
My Nordmende television blue light below screen continually flashing & no tv screen.
Question edited for clarity, your television is 'Nordmende', not 'Norfmende'.
Time for a new one, but try the power reset first as mentioned here.
The standby light on my nordmende tv keeps flashing
JustAnswer https://www.justanswer.com > TV Problems
Sep 27, 2012 - Unfortunately, the symptoms you are experiencing (flashing power/status light, tv won't power on) are generally symptomatic of an internal ...
1 answer · Top answer: p0llinate : Hello, and welcome to justanswer, a pay site for expert technical help. My ...
How to fix my nordmende tv as blue light is flashing and ...
Ask Me Fast https://www.askmefast.com > How_to_fix_my_nordm...
Its the power supply board, capacitor(s) have gone. Solder on new or replace board. source: 26" lowry tv red and blue standby light flashing and tv wont turn on?
Westinghouse ew32s5kw tv red light shows power is going to unit pressing power turns indicator light from red to blue for a brief moment then back to red.
I had the same problem on my Westinghouse 32 inch TV. The internal main power supply went bad and had to be replaced. I had a TV repair shop do it. It was about 8 years ago. Haven't had a problem since. I think it cost about $70 for parts and labor. Nowadays TVs are pretty much a throw away item if they go bad. TV repair shops are getting hard to find plus the cost of TVs has come down so much sometimes you can get a new set for what the repair would cost!
1helpful
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
I get blue/ red light instead of red/blue wen m pairing wid my iphone
Try resetting the headset: When plugging in the AC charger, hold the power/pair button down. The headphones will show a solid red or blue light when they have been successfully reset.
Good luck from Headsets Direct - 800-914-7996.
Status light stays red no tv no power light
TV requires service. but try to reset it by pressing system reset
2helpful
I have Logitech wireless headphones for my Ipod, and I can't get them to work. When I press the on button on both pieces, it goes solid red and not blue.
Visit the Logitech support website and find the instructions to reset and pair them. Since yours is for an Ipod I'm assuming you have the older white/grey model and not the freepulse headphones. The procedure is not the same. From memory the procedure it to reset both (look for the small hole to insert a paperclip). Once both are reset begin with the transmitter. Hold the power button down for about 30 seconds until the light flashes red and blue. When it does do the same for the button of the headphone until it flashes red and blue. When both are flashing red and blue they should pair together and the lights should turn solid blue..
Can't power on
try unplugging the dvd player then plug it back in as this treats it like a reset.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
