A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Unplug it to disconnect the electrical power.
Reconnect it.
Look for a "sensor" that determines when the hopper is filled -- is that "gummed-up" or "jammed" ?
It does not need to be descaled as this is not the descaling indicator...The water circuit needs to be primed. Turn the knob to the water drop and drain water into a bowl. Hold the water drop button down while this is happening until the red light turns green. Presto.
make sure all the doors are closed, brew group, tray, water, and disposal are all seated closed.
have you cleaned the brew group?
something stuck in the grinder?
got beans and water?
This red light is to indicate if the water tank needs filling, if the bean hopper needs filling, or if the brew unit is not in the unit (after cleaning) or not in the correct position.
Fill beans before they run out!
If you hear the grinder running empty, press the same button you pressed to start making coffe to cancel the current cup -or, if some beans were ground, stop the water a bit earlier to make a shorter coffe using the same method (press the button you pressed to start the cup). The auto-detect of beans missing is a very minor and largely useless feature.
