Kodak EasyShare Z740 Digital Camera Logo
Posted on Apr 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camara wont stay turned on
I have the kodak easyshare Z740 camara and I can turn it on but then it flashs black and turns off. I can review my memory card and its stays turned on ???
Anonymous
Level 3:
  • Master 2,335 Answers
  • Posted on May 01, 2010
Anonymous
Master
Level 3:
Answers
2335
Questions
0
Helped
882327
Points
4663
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
Hi, my Kodak EasyShare Z740 turns off after taking one picture, or even just by focusing.
That sounds like your batteries are worn out because they are rechargeable. The trickle charger doesn't have enough milli-amps to run the camera only to charge the battery.
https://www.google.com/search?q=kodak+easyshare+z740+battery+replacement
tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
on May 01, 2010 • Cameras
tip
I hope that helps.
The lens thing gets stuck wont go in or out and camera shuts down
I may be able to help with your Kodak EasyShare Z740 with a stuck lens.
I hope that helps.
If i go to favorites it works fine switch over to the camara it starts to work the screen goes off and stops
I may be able to help with your Kodak EasyShare Z740 that works in favorites but turns off in camera mode. This is a common problem.
This is either caused by a problem extending the lens, or a computer brain problem that is reset with a button press sequence.
I hope that helps.
My z740 camera will not stay on
I hope that helps.
Camera won't stay on
I hope that helps.
My camera lets me see pictures but not take any
I hope that helps.
Kodak easyshare Z740
I hope that helps.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
