Konica Minolta bizhub 180 All-In-One Printer Logo
Posted on Apr 15, 2010
Message on screen: M2 - Konica Minolta bizhub 180 All-In-One Printer
Anonymous
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Apr 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
6
Questions
Helped
7046
Points
20
This is Consumables Counter, you have to reset counter in programming
utility, stop, 0 , 0 , stop, 0 , 1,,,,,,
Counter,,, consumables set to clear then panel rest
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 18, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
710
Points
How to reset the counter
1helpful
How can i unlock my xperia m2 screen on 0832011871?
Download and install Sony's Passlock Remover on your PC. Once installed, connect your device and follow the prompts.
2answers
Proceed to continue using the machine konica minolta bizhub 165 when I get the message error M2
http://www.copytechnet.com/forums/konica-minolta/62595-konika-minolta-bizhub-163-error-code-m2.html
2answers
How to remove on screen preventive maintenance time m5
there is no M5 preventive maintenance only M2 and M3 please conform
M1 m2 m4 screen messaege
Utility button then stop 00 stop 01. Then use arrows to clear data screen then clear counters. Has the drum and developer been replace do that before clearing the counters
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
I have message call service(M2) so how to clear this problem
M2 message refer to consumables life end.Enter in service mode,select a counter and select consumables and read the counter.Change the consumables when indicated and reset the counter to 0.I hope you have KM Dialta 450 or Dialta 520.If you have other KM model please tell me a model type for more help.
I have a cracked screen (toshiba tecra m2) and have an opportunity to buy a replacement screen from a tecra m2 S630 that is broken. Are the screens interchangeable?
Can't answer your screen question, but I can propose a workaround - your Toshiba laptop has a
monitor port on the back - you can plug in a standard monitor, and ignore the cracked screen
temporarily until you can replace it. hope this helps
The monitor port is the 15-pin analog VGA D-shell (female) port.
The online User's Guide for your Toshiba Tecra m2-S630
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=596874&rpn=PTM20U&modelFilter=M2-S630&selCategory=2756709&selFamily=1073768664
1helpful
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
4helpful
How do I earase the M2 button that is always on my screen?
Clear the display so that zero shows, then press STO M2 to store zero in the M2 registry. Any time there is a non-zero number stored in M1, M2 or M3, you will see those memories in the display to remind you there's something stored. There is no "clear memory" function on the TI-30XA, you have to store zero in the memory to clear M1, M2 or M3 from the display.
David
5helpful
M1 m2 m3
STO the value zero into whichever memory has something stored and M1, M2 or M3 will disappear
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
