In almost all cases where the set is taking a long time to turn on and then turning off it will be the Power Supply board that will have bulging capacitors, usually three to five. Look on the upper right side of the Power Supply and look for any blown caps. You can replace these caps and you will be fine. Now the other cause can be the Power Switch is shorting out. You can disconnect the the Power Switch but not the IR sensor and then turn ON the set with your TV remote and see if this stops the problem. If you are not skilled in component level repair on the Power Supply board then buy a new Power Supply board and install it.
