Konica Minolta bizhub 250 All-In-One Laser Printer Logo
Posted on Apr 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Malfunction c-2552 konica Minolta c252p - Konica Minolta bizhub 250 All-In-One Laser Printer
Anonymous
Level 2:
Sniper:
  • Expert 62 Answers
  • Posted on Apr 26, 2010
Anonymous
Expert
Level 2:
Sniper:
Answers
62
Questions
0
Helped
83114
Points
160
Hi, C-2552 on the bizhub C250 means the sensor that measures the Cyan toner level has detected it as abnormally high.
It's likely to be the Cyan Imaging Unit has failed. But try this first..
Remove the Cyan Imaging Unit, give it a gentle tilt (45 degrees or so). Tilt it backwards and forwards a few times, then refit.
Hopefully the code will be gone.
If not, it sounds like the Cyan Imaging Unit is faulty.
Regards
Tam
How do i reset error c20 in bizhub konica minolta
OHP sensor malfunction had a tech check it out and or replace
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Migicolor 2552 service call 1B
check the fuser unit
Kronica minolta 550 codigo de error c-2552
cyan toner issue replace cyan image unit
C200 bizhub error code c 2552
Abnormally high toner density detected cyan TCR sensor
C 1038
Open the front door, up left small access cover remove and push trouble reset button. Once reset the malfunction and turn OFF and ON the Power Switch. If the same malfunction is still detected, check cables for proper connection and, if they are okay, change PWB-B. If you can find one, quite old machine, a legacy Minolta, now Konica MInolta
Error c-0200
konica minolta bizhub malfunction detected error code c-0200
Colour Profiles for the Konica-Minolta BizHub C252P
For this type of colour output, such as InDesign you will really need a Fiery. This is professional colour running in Psotscript.
Without this you are going to have inconsistent results.
Depending on the Model will be how well it supports ICC profiles. the most recent "tuxedo line" comes with a profile downloader that works well with custom profiles.
4helpful
Copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
2answers
Trying to use photo copierfrom the touch pad
eee, what version machine you have ?
C252 is copier
C252p is a printer version without copy function
what are you trying to to? copy ? scan ? print ? fax ?
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
