The code is a10 this is normally a heating issue but could also be a foaming problem which could also be your poor washing results put a cleaner through with a lime scale remover
If you are in a cold area, having it outside isn't helping you. Tank less heaters only raise the water temperature 40 - 70 degrees. If you had 50 degree water coming in and it is 35 degrees outside, you will be lucky to get 90 degree water.
Torque Specifications
TORQUE SPECIFICATIONS
All readings in ft. lbs.
Year
Engine Displacement Liters (VIN)
Cylinder Head Bolts
Main Bearing Bolts
Rod Brearing Bolts
Crankshaft Damper Bolts
Flywheel Bolts
Manifold
Intake
Exhaust
Spark Plugs
Oil Pan Drain Plug
2001
2.2 (4)
①
70
38
77 ②
55
③
10
13
18
2.4 (T)
④
⑤
⑥
⑦
⑧
⑨
⑩
13
18
NA: Not Available
① Step 1: Long bolts: 46 ft. lbs.
Step 2: Short bolts: 43 ft. lbs.
Step 3: Long bolts an additional 90 degree turn
Step 4: Short bolts an additional 90 degree turn
② Center bolt spec shown; Pulley-to-hub bolts: 37 ft. lbs.
③ Bolts: 17 ft. lbs.
Nuts: 17 ft. lbs.
Studs: 9 ft. lbs.
④ Step 1: bolts 1-8; 40 ft. lbs.
Step 2: bolts 9-10: 30 ft. lbs.
Step 3: An additional 90 degree turn
⑤ 15 ft. lbs. plus 90 degrees
⑥ 18 ft. lbs. plus 80 degrees
⑦ 129 ft. lbs. plus 90 degrees
⑧ 15 ft. lbs. plus 45 degrees
⑨ Nuts: 18 ft. lbs.
Studs: 97 inch lbs.
⑩ Nuts: 31 ft. lbs.
Studs: 97 inch lbs.
⑪ Step 1: Long bolts: 2 ft. lbs.
Step 2: plus an additional 155 degrees
⑫ 15 ft. lbs. plus 70 degrees
⑬ 18 ft. lbs. plus 100 degrees
⑭ 74 ft. lbs. plus 125 degrees
⑮ 39 ft. lbs. plus 25 degrees
⑯ Bolts: 89 inch lbs.
Nuts: 89 inch lbs.
Studs: 53 inch lbs.
⑰ Bolts: 89 inch lbs.
Studs: 12 ft. lbs.
I have a Hotpoint Aquarius SDW 60 The delay 3hr &12hr lights are flashing at the same time. Machine won't start. If the door is slamed shut. It get stuck on the Fast & Prewash 40 degree cycle. and stays there.
I had the same problem with my Hotpoint FDW60 and read all the online reviews about how baddly made the FDW60 is and after taking it apart I totally agree.
As the warning lights were indicating a faulty heating element I checked it to find that it was not working. I bought a replacement for £43 at my local electrical store (I think they then ordered it online). Taking the bottom off is easy but once off, it is very difficult to actually get to the element, but it can be done. I had to buy new hose clips to fasten the rubber pipe each side too. It has been on twice today and so far so good.
I have read some message boards and have seen that some people have had to replace the element a number of times, so I will wait and see what happens.
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
