Question about Lenovo IdeaPad S10-42312CU Notebook
Laptop format format step for lenovo y550
  • Lenovo Master
  • 12,061 Answers
Just bought Lenovo S10 and so unlucky that window crashed. So have to restore my Lenovo S10 to factory settings. Can’t really find how ot restore to factory settings in Lenovo S10 from the User Manual. So check from google, after many many search, finally found the solution.
For Lenovo S10 to restore to factory settings follow the steps below:-
  • Turn off your Lenovo. (i mean shut down and make sure it’s power off)
  • Now press on the “One Key Recovery” key at the top of your Keyboard, your Lenovo S10 should boot up. Else hold down the “One Key Recovery” key until it boot up.
  • Now you may choose “Restore to factory settings” from the screen and proceed for the restoration.
    ** the restoration will first check if your windows files has been corrupted, if yes, then it will restore it to the original state and no restore is required. else it will continue with the restoration
Posted on Apr 15, 2010
  • juddboydston Apr 07, 2011
    Is there any other way? This does not work on my S10 it just boots up no format options when the OKR is pushed.
  • 560 Answers
Shut down your Lenovo laptop as normal, clicking "Start" in the bottom left corner of the screen then "Turn Off Computer." A screen appears with various shut-down options; click "Turn Off." The computer powers down.
Press the square button above the power switch marked with an arched arrow. The computer turns on in "OneKey Recovery System" mode.
Select "Restore to Factory Default" using the arrow buttons and hit "Enter." The computer erases all the information on the C: drive, replacing it with factory default data stored in a hidden disk partition. The process takes longer if you have a large amount of data on your hard disk.
I hope it will work for you.
Feel free to get technical assistance at http://www.vtechsquad.com/lenovo-support/ if you get any issue with your Lenovo notebook/laptop/desktop.
Posted on Oct 05, 2012
3 Suggested Answers
SOURCE:
melaiii
  • 35 Answers
SOURCE: help to install memory on a lenovo laptop y550
1. remove the battery first by turning the notebook over. unlock and hold the latch, and remove the battery.
2. remove 4 screews on the CPU door and then remove the thermal door. (see picture 1)
3. Pull the two latches securing the memory and pop the memory module up to 45 degree angles, and then pull out the module in that angle (see picture 2)
Posted on Apr 09, 2010
sanguine
  • 369 Answers
SOURCE: format laptop lenovo y550
Note: Format would delete all of the data(like pictures, documents.) from the computer. Make sure, you back up all of your important data before formating the hard drive.
1. Insert operating system disk. 2. Shut down and restart the computer.As soon as, you restart the computer, start tapping 'Spacebar' key. Now, this would start loading from disk. 3.Hit F8 to accept the license agreement. 4.Hit enter 5. Enter Enter again and follow the on screen instruction and this would format your hard drive.
Note: once you format the hard drive, you would need to install drivers as well. Make sure you have the drivers and utilities disk as well.
Y550 cmos battery
The CMOS battery on the Y550 is considered to be non-replaceable by Lenovo. It is soldered directly to the motherboard itself. You can check out this youtube video on the disassembly of the Y550. At the 14:22 minute mark on the video you can see where this battery is. At the top right of the video you will see a big green INTEL chip (upside down). To the right of the bottom of the Intel chip, you will see a round blue component. This is the battery.
If you were handy with a soldering iron, you could un-solder and replace this battery, but the average consumer would not be able to replace it. Lenovo will most likely require you to purchase a new motherboard.
Here is a better look at the battery from an ebay listing:
http://www.ebay.com/itm/OEM-LENOVO-IDEAPAD-Y550-INTEL-MOTHERBOARD-mPGA478MN-SOCKET-KIWB1-LA-4602P-/171885234728?hash=item2805288a28
In this picture the battery is the blue round button looking component to the left of the Intel chip.
Apr 07, 2014 | Lenovo IdeaPad Y550 Notebook
Lenovo Y550 has been sitting without being used for many months. I tried to power up today. It starts, the disk drive symbol flashes for a second or two, and then it stops. I've tried removing the...
If it works with the AC cord plugged in and not on battery, then you have a dead battery. Even when plugging in the battery it's going to try and charge the battery and THEN provide the computer with power. Get a new battery.
Oct 25, 2013 | Lenovo Y550 Notebook
Lenovo Y550 has been sitting without being used for many months. I tried to power up today with the AC adapter plugged in. It tries to start, the disk drive symbol flashes on for a second of two, and...
The power supply may have an issue. I would leave it charging in the off condition over night and if the battery takes a charge and the system starts up when you turn the laptop on, that will prove the power supply ... that may well recover as the capacitors re form.
I want intall wedcam for lenovo Y550
Hello,the Lenovo Y550 has an integrated Webcam located at the top of the monitor. It should already be installed but if you need the drivers you can here --> http://consumersupport.lenovo.com/ot/en/driversdownloads/Drivers_Show_1759.html
Nov 17, 2011 | Lenovo IdeaPad Y550 Notebook
Can't see driver for webcam in lenovo y550
Hi, To get software driver of that lenovo y550 web camera and other lenovo y550 driver click the following link http://support.lenovo.com/en_US/downloads/default.page? just click choose Camera Then click select camera driver to get compatible driver.
Hope can help you. Thanks for using Fixya
Jul 19, 2011 | Computers & Internet
MY LENOVO Y550 IDEAPAD WEBCAM IS NOT WARKING. HOW CAN I DOWNLODE DIRVER?
Click on the link below and scroll the page down to obtain the Lenovo 3000 Y410 laptop webcam driver:
http://www-307.ibm.com/pc/support/site.wss/MIGR-68104.html#camera
Dec 22, 2010 | Lenovo 3000 Y410 Laptop
I own a Lenovo IdeaPad Y550 with Windows 7. For as long as I've owned the laptop, the webcam has always worked. However, now, the laptop does not seem to recognize the built-in webcam at all. Help?
actually you just need to download the driver on lenovo website, consumersupport.lenovo.com is the website then type in your Serial number and look for your driver for your web cam
Jun 16, 2010 | Lenovo IdeaPad Y550 Notebook
Format laptop lenovo y550
Apr 15, 2010 | ASUS Computers & Internet
Help to install memory on a lenovo laptop y550
Jan 04, 2010 | Lenovo IdeaPad Y550 Notebook
Lenovo IdeaPad S10-42312CU Notebook Logo
1,889 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
