When transferring media from lg connect to pc via usb cable switch connection setting on cell to sd card (you have bluetooth and data) data is the settings for the cell softwares
Have you tried updating the drivers in your computer?
Try scanning it with RadarSync so that you can make sure that it's not the drivers that's causing the problem. You can also use the same software to update them.
you can either use Bluetooth if your pc has Bluetooth or use a usb cable to transfer the photos. the third option is use a memory card to transfer the photos
When you connect the phone to your computer, it should ask whether you want to use it as a Mass Storage or via the PC Suite. Wait for the driver detection process and then go to My Computer. You should see your cellphone as a storage device. Browse the folder and then from there, you can transfer your files.
Hey I am not entirely sure if this is correct, but I had the same problem as you...the reason that message is coming up is because you cannot load videos or images from your phones internal memory to the computer. In order to load either images or videos you will have to buy the micro SD card and put your multimedia on it. Once you do this, the phone should (it did with mine) download the needed drivers and you can easily transfer anything between the card and the computer. Hope this helps
