Question about Lenovo 3000 C200 Notebook
Bios update 3000 c200
Idownloaded the Bios update from Lenovo web page v 3.12 ok.
Followed procedure, Run as administrator AdRomLdr, Phlash all runs Ok and appears to complete sucessfully and computer shutdown.
when I reboot, pressF1 to look at Bios ver installed it is still 1.08
Update must not have worked ??
Any ideas how to get it to work ???
laptop is still working ok
Regards
  • 942 Answers
Hi deartone, you can try these steps:
You can power drain the pc if the bios won't update.. Turn off the pc
then unplug cables from the desktop or laptop then remove the battery (only on laptop) , then press and hold the power button for 5 seconds.
Then replug all cables and batteries. Then turn on the pc and check the Bios if it updates.
You can call our technical support if it isn't work at 1-877-4-536686.
we are open 24/7...
Posted on May 08, 2010
SOURCE:
Bad file name after BIOS update...
No need to update bios if windows are normally run..!
Oct 21, 2012 | Lenovo Computers & Internet
Bios update mc7801u...from 9911 to 9930 wont update using phlash tells me error 144...do just says cannot update the bios
If your laptop thinks it is running off of battery power, phlash will crop up with an error such as yours. Make sure you are running on AC power, and remove the battery before running phlash.
Jun 16, 2011 | Gateway MC7801u Notebook
Hi i need a expert to resolve my laptop Acer Aspire 1640z . I was upgrading my bios from 3a19 to 3A24 and now... after powering on, i hear 1 long beep and 2 short beeps and my screen is black. Nothing...
According to my troubleshooting manual of Acer Aspire 4520-Z3 about
BIOS Flash Utility:
The BIOS flash memory update is required for the following conditions:
New versions of system programs
New features or options
Restore a BIOS when it becomes corrupted.
Use the Phlash utility to update the system BIOS flash ROM.
NOTE:
If you do not have a crisis recovery diskette at hand, then you should
create a Crisis Recovery Diskette before you use the Phlash utility.
Do not install memory-related drivers (XMS, EMS, DPMI) when you use the Phlash.
Please use the AC adaptor power supply when you run the Phlash utility.
If the battery pack does not contain enough power to finish BIOS flash,
you may not boot the system because the BIOS is not completely loaded.
Follow the steps below to run the Phlash.
1. Prepare a bootable diskette.
2. Copy the flash utilities to the bootable diskette.
3. Then boot the system from the bootable diskette.
The flash utility has auto-execution function.
You need to prepare a bootable Flashdisk into dos mode
then you should search for the above mentioned crisis recovery
diskett and transfer its content to the flashdisk.
I read from another forum that for recovery of Aspire 4520 problem
can be done through pressing of the keys combination as follows:
press FN + ESC and hold them, then just hit the power on button
and release it, after awhile "the power button" should blink red,
release the keys FN+ESC and don't touch anything.
After successful of recover the bios it should restart normally.
That happen after 20-30 minutes. If it doesn't restart just repeat the
process.
Hope it helps
Mar 09, 2011 | Computers & Internet
Experiencing following on boot: Lenovo 3000 C200 PC Notebook Error 0701 usb current hc port. Both USB ports disabled. Any advice on remedy.
Kindly set the BIOS on start up. You may have disabled the USB. If the matter persists then check the drivers in the device manager if they are correctly installed. Or if the problem is your Operating System then have it updated by installing online updates. This would install necessary drivers. If the problem still persists then, look for a computer technician to check your laptop.
Jan 31, 2011 | Lenovo 3000 C200 Notebook
I updated the bios and now it will not boot up
There is NO real reason why you cannot reflash your bios back to the way it was.... You simply need to find out what type your, bios is... and there are many programs that will address your BIOS and re-flash it. This is unless your BIOS is so broken that the machine will NOT even read a DVD memory stick or driver at all. What happens if you try again?
Some links below... all about it.
forums.lenovo.com/t5/Lenovo-3000-and-Value-line/.../198717 forum.lenovo.com/t5/T61-and-prior-T-series...bad-bios/.../true;...
Mar 01, 2010 | Lenovo 3000 C200 8922 - Celeron M 420 1.6...
Reset bios password for lenovo 3000 laptop
how to remove bios password in my lenovo laptop
Dec 10, 2008 | Lenovo 3000 C200 Notebook
Sound driver lenovo 3000 c200 laptop
open your control pannel and click on user settings. from here you can change administrative option!!!
Jul 29, 2008 | Lenovo 3000 C200 Notebook
So how do I get inot my laptop?
Have you tried clicking ok with no password or typing Administrator. Also, check the bios and see fi there is a password setting turned on in there.
May 23, 2008 | Lenovo 3000 C200 Notebook
Lenovo memory problem
crucial wasn't the problem.
the problem was solved by me doing a bios update.
they shipped the unit with the pci configured for 1 gig.
not 1.5,2,3 or 4.
I had to go for broke and pray that the 63af08 update had something in it,they said nothing about a memory upgrade period!
Here are 2 links for the solution. WHEW!
c.gif Lenovo Support & downloads - BIOS Update Utility - 3000 C200, N100
Specify AdRomLdr.exe with the full path name where you extracted this package and click OK. Example: C:\DRIVERS\WIN\FLASH\63af08US\AdRomLdr.exe Follow the instructions on the screen. After the update has been completed, the computer will restart
URL: http://www-307.ibm.com/pc/support/site.wss/document.... c.gif c.gif 2. c.gif BIOS Update Utility - 3000 C200, N100
URL: http://www-307.ibm.com/pc/support/site.wss/document.... c.gif c.gif c.gif c.gif
Dec 12, 2007 | Lenovo 3000 C200 Notebook
Lenovo 3000 C200 Notebook Logo
326 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
