I found a pdf manual
here and it shows that this computer does not have SATA ports, but does have 2 IDE ports, so if it's an IDE hard drive you want to install then you should be able to. However, your 2nd IDE port is likely used by a cd/dvd rom drive, so unless you are replacing the hard drive rather than adding one, you would need to remove the disc drive. There are very affordable external usb disc drives available.
