Polaroid TDX-01930B 19 in. LCD HDTV Logo
Posted on Apr 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remote won't work. Bought a replacement but still no joy. Any ideas? TV works OK on side buttons.
Chi Chu
Level 3:
  • Polaroid Master 8,457 Answers
  • Posted on Apr 14, 2010
Chi Chu
Polaroid Master
Level 3:
Answers
8457
Questions
0
Helped
2822900
Points
26282
U bought an original remote right?If u bought an a universal remote.U must have to enter the codes for ur tv model in ur univeral remote manual.
  • djdinges Apr 22, 2011
    We have the same problem with the remote that came with the television. Only volume control is activated by almost every button on the remote, and most others do not work. The remote BURNS through batteries like kindling wood. Our cable remote also activates the volume control with EVERY button we push. UGH!
I bought 2008 Subaru tribeca and the DVD remote si not working so i bought a new one from Subaru but it's still not working but the unit is ok any idea?
remote volume control not working Questions & Answers ...
www.fixya.com > Forum > Tags
I bought a Philips PM3S universal remote contro today, thinking that the TV needed one specifically. After one code try, . ... Volume buttons of Sony Remote control is not working for Akai TV. ... not working for Akai TV ... Radio volume control on 2008 Subaru Tribeca does not ... www.fixya.com/. ... RCA TruFlat 27F520T 27" TV.
Media Center Entertainment for Tribeca - SB9T.com
I bought a seiki 48 inch TV about 2 months ago. Now the remote has stopped working. Any ideas
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
My tv is keep turning itself on and off and my remote has randomly stopped working, ive had the plug out the wall the past 6 hours nd no joy, any ideas? I've put new batteries in the remote 2
Sounds like a power board issue? Dry joints on the main board? Capacitors may have issues.? I would not go opening up the TV if you are not aware of the potential dangers.
Ive just bought a 22 inch lg tv, tuned in ok but remote is now not working, wont do anything, wont even put tv in standby mode. Any ideas?
unplug tv, take batteries out of remote. plug tv back in, replace batteries. best idea i have. sometimes that resets the devices. good luck
1helpful
I have an Audiosonic KM2120 bought from gumtree but can't get the remote to work, any help gratefully appreciated!
Check the remote control for its infra-red emission.Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV.If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience.Pull up older posts.http://electronicshelponline.blogspot.com/If the remote control is found OK; check and replace the infra-red sensor inside the TV.Contact any service technician.
1helpful
2answers
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Remote to tv doesn't work
Hello
Check the remote first for its infrared emission. If it is OK, the infrared sensor inside your tV is faulty. It should be replaced with same type and number. It can be located just behind the infrared window at the front panel of your Tv. You ahve to open your TV ot access it. It will have three solder terminals, and will look somehat brownish black in colour. Will look like this.
4helpful
2answers
Universal remote (GE 24116) that i purchased to replace the lost remove control for my sanyo 42 inch tv won't work. the arrow buttons don't work in the menu which is the only reason I bought the...
Hi, You need a code to match with your TV remote. The codes for the Ge universal remote for Sanyo are 0049 0097 0110 0004 0268 0012 0108 0180. You will have to try each code seperately untill you get one that works. Good luck.
1helpful
I have a Technika 24in tv / dvd. The remote works fine except some of the buttons do not perform the desired function. i.e. the dvd menu button does not bring up the dvd main menu but a system screen. I...
Hi
The software version decides the function that coincide with remote signal. If the remotes' infrared signal frequency differ to the receiving spctrrum of the software, it won't work well. You must have the remote of the present TV itsef to work in coincide with the button actions. Just get it. There is no other way. OK.
Top Polaroid Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
