Panasonic Viera TH-42PZ85U 42 in. Plasma TV Logo
Posted on Apr 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know how to set up the TV - Panasonic Viera TH-42PZ85U 42 in. Plasma TV
Anonymous
Level 2:
Scholar:
  • Expert 103 Answers
  • Posted on Apr 14, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
103
Questions
0
Helped
42779
Points
335
Here's a link to the user manual for your tv. It looks like page 6 through page 12 describes how to set up the tv.
http://service.us.panasonic.com/OPERMANPDF/TH42PZ85U.PDF
I hope this helps, and good luck! Sincerely, Der Strom
Hooking up dvd player rca type and tv just keeps showing... no signal
Hummmm... the YELLOW RCA should be your VIDEO cable and have VIDEO signals.
Are you SURE your TV is set to the CORRECT "INPUT" SETTING? And DO YOU hear and audio>?
Anthony
My tv goes off and on by its self
I will need the model number of your set and will also need to know when it goes off does the set go out completely with no audio or screen? Also does the power indicator change colors or blink after the set goes out? Let e know and I will assist you with the issue.
I had my playstion 3 hooked up to an hd tv and then i hooked it up to a regular tv..the tv isnt reconizing the playstation at alll..i dont know what to do,
Hook the ps3 back up to the hd tv. From here you need to acces the settings resolution options. Set the resolution to 480 (standard tv). Once set for standard, turn off, disconnect, and set up to non hd tv. Problem solved.
Trying to find a tv stand for this tv. what is the weight of the tv
  • Dimensions: 29" H, 30 1/8" W, 22 1/2" D
  • Approx. Shipping Weight: 120 Lbs. I would get a stand that gives you some extra capacity for safety. Measure the base of the TV so you know the dimensions of the sets "footprint" to know the dimensions you need for the stands shelf to accomodate the set. Good luck
  • 0helpful
    Urc-4700B00 tv was given to me,girlfriend don't
    It is the remote that needs to have a code entered to recognize your set. Not knowing if you have the original remote (it shouldn't need a code at all), no one can help you yet.
    Also, if you have a remote that didn't come with the set, your chances are slim that your particular set will be among those compatible with the remote. If that URC number is from the remote, you need to go to this website to find the code list:
    Remotes
    Need to know if LG503 surround sound works through normal tv
    it comes auto set up as hdmi so needs to be set up under scart
    2answers
    Picture wider than the screen
    hello. can you tell me do you have your manul that came with your tv.? if not that's ok . we can fix it . it's in your tv's menu set up. you need to bring up up on your screen and scrol down to the video setting and there you will need to change the size of it's format. witch will have diffrent setting in size. and they could say setting for STANDARD or THEATER FULL OR WIDE . !!! or it's could have set of number's like your computer use's like 800 by 600 , or 1024 by 768 and you have the ideal what i "am saying.? you need to change this to fix your set. you should set it to standard.!!! in the menu. some set's have a Demonstration mode you can use to to see how your tv work's for setting it up.? so go try what i have told you and get back to me and let me know . ok "GOOD LUCK" and THANK YOU FOR USING FIXYA.COM
    2answers
    How to reset lamp timer
    Go to the menu and you'll find lamp timer section.
    4helpful
    Is my tv digital compatible or not
    https://www.dtv2009.gov/FAQ.aspx What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
    Here are some general guidelines that may help:
    TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
    If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
