"H-SET" is the "0" hands position.To do this right,go to manual (link below) by using the module nbr found on the back cover (4 digit code in a frame). Timepieces Watches Manuals CASIO
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
I had a casio and the method was; press the mode button until the display says "HS", then press the 2 or 4 o'clock buttons to adjust the hands to match the digital time; then press mode button until normal operation is achieved.
My watch was a different model to yours, so if this does not work, then you can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
go to support page on casio. and get your manual. youll probably gonna look for a 3 or 4 digit number located at the back of your watch. once you got the manual. go to page 4. and follow the steps of "Hand Home Position Correction". that should fix it.
i also have ga 110c and i have encountered this issue
Not sure why but the "home position" may be out of sync. Look under "Adjusting the home positions" in the owner's manual and follow directions to correct this problem.
I have the same watch and thought I had the same problem. Casio's website actually DOES have the downloadable manual for this watch in their Support section, though it's kind of burried in their "Watch Manual Archives" section. Try to copy this address into your browser: http://world.casio.com/wat/download/en/manual/ FYI, the manual number you'll need to search for is shown in a rectangle on the back of the watch. In my case it was # 3054. When I downloaded the manual and read it, I learned how to confirm auto-updating is activated, and how to do manual updating. In my case, I was trying it from too far inside my house with a weak signal. When I set all of the settings as described and placed the watch in the window with 12:00 pointing outside as shown in their diagrams, the manual update feature worked like a champ. I also learned about a couple of other neat features hidden in the watch. Too bad the manual didn't come with the watch when I bought it; it would have saved me lots of frustration. Hope this helps you!
