Envision 19" Widescreen Flat Panel LCD Monitor Logo
Posted on Apr 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The on/off of pc monitor (LCD) is blinking.
The on/off of pc monitor is blinking. if there is not input from computer, in monitor displayed 'burning....'. what the problem regarding indications above?
and what must to do?
before hand, thank for your helps.
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Apr 14, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366082
Points
33650
Most LCD monitor (depends on the brand) power indicator light will either turn from Green to Amber, or flashing Amber, or flashing green, when it does not detect video signal feeding it. So it may be normal with your monitor. Are you haivng problem with the display? If it displays he pictue OK then there is nothing to worry about.
Works for three seconds at a time
Its becoz there is no signal from your PC. Check the input of LCD monitor i think there might be problem with that cable! ?Mostly the cable gets weired in long run. so check thoroughly! It might work. Or else you have to repair the LCD!
Hyundai L19T lcd monitor. Monitor powers up but power indicator light keep blinking and display image just blinking too. What may cause that?
Sounds like you have some bad electrolytic capacitors.
If you are tech savvy, open up the unit and look for capacitors that have bulging tops or leaking electrolyte / bulging at the bottom and replace any/all that look like this.
In most cases, this will fix you right up quick.
It's the right age for this to be the most likely issue.
The capacitors will be near the power input and the inverter stages of the circuitry.
Compaq TFT 8020 Display Problim
have you tried going to menu and setting back to factory defaults? also, disconnect power cable and leave unplugged for 1 minute. Plug back in then see if problem is still there. Otherwise, something is wrong with the monitor that will need serviced or exchanged.
Power problem
low power consubtion first on ur moniter then cpu
8helpful
3answers
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
VGA input not displaying
Hi, insert the monitor driver of screen on swicth reinstall driver in order to detect screen.
Top Envision Computers & Internet Experts
Alexander
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
