TS06 DEC 05
Keyless Entry - Transmitter(s) InoperativeThere was a recall in DEC. 05 for this particular vehicles remote transmitter system....though im not sure if they would do service free of charge now...
Moving along...if you have no working transmitter, you have to do the following to get it working again:
* Ensure vehicle audio PIN number is known or audio PIN security system is deactivated prior to battery disconnection.
* Ensure a door is open
* Disconnect the negative battery cable, wait minimum 5 seconds then reconnect
* Within 20 seconds of reconnecting the battery cable, insert the keyin ignition then cycle the ignition key from the "ACC" position to the"ON" position 20 times, leaving the key in the "OFF" position after thetwentieth turn.
* the vehicle's indicators will flash 20 times to indicate successfulentry. NOTE: Should the indicators fail to flash, wait 5 seconds thenquickly turn the ignition switch from the "ACC" to "ON" position 10times, leave the ignition "OFF" after the 10th turn and wait 15 secondsthen recycle the ignition switch 20 times.
* the vehicle's indicators will flash 20 times to indicate successful entry.
* within 10 seconds of the indicators having ceased flashing, press the button once on each transmitter.
* turn the ignition key to the "ON" position to lock in and exit from the programming mode.
And if you have even 1 transmitter that does work, its not nearly as difficult:
* ensure a door is open
* remove key from ignition
* lock the doors using the transmitter
* unlock the doors using the transmitter
Within 20 seconds of unlocking, insert key in ignition, turn theignition key from the "ACC" position to the "ON" position 20 times,leaving the key in the "OFF" position after the twentieth turn.
The vehicle's indicators will flash 20 times to indicate successful entry.
Within 10 seconds of the indicators having ceased flashing, press thebutton once on each transmitter. Once finished, turn the ignition keyto the "ON" position to lock in and exit from the programming mode.
Hope this helped,
Jem
Sorry, worded it wrong, it already is rapidly flashing, yes it is a bluetooth.
I released it about an hour ago, and it is still rapidly flashing?
the transmitter wont turn off, the red and blue light on the transmitter is on.. i cant reset it, i tried holdng on to the button many times it wont blink or turn off... what can i do?
