OK THE WIFE SAYS PAPER PIECES ALOT OF EM CLOGGED THE FILTER THEN IT NEVER HAS HEATED UP SINCE I CLEANED EVERYTHING OUT TOKK BACK OF DRYER OFF REMOVED ENTIRE VENT ASSEMBLY EXHAUST COIL AND SHOPPED VAC OUT REPLACED VENT RAN DRYER AFTER A FEW I SAW FLAMES AND INSIDE WAS HOT PUT UT BACK TOGETHER AND IT HEATS UP FOR A FEW NEVER REAL HOT THEN IT TURNS OFF HEAT TOTALLY AND THEN I SMELL GAS IN HOUSE AND OUT VENT SO THE GAS FLOW IS RELEASED BUT NO HEAT WOULD IT BE THE IGNITOR CYLINOIDE THERMAS STAT ANY HELP I MIGHT THINK OF MORE LATER
I would check the thermostat first then change the igniter
Testimonial: "i will try that ty so much i will get back to you"
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
