How to find a serial number for software/hardware
Use the information in this article at your own risk. Always keep your computer firewall and virus programs up to date and activated.
Serial numbers for software are usually needed to
activate or verify the software was purchased from the vendor, to obtain updates and to install the software. Sometimes, you can misplace or be
unable to locate the serial number.There are a couple of ways to
obtain a serial number for software, some are
legal and others
illegal. I will go over common methods to help you
obtain the serial numbers.
-A easy and legal way to
obtain software serial numbers is simply by
purchasing the software. A lot of the times when you purchase the software directly from a website, the website will provide you with the serial either directly on the purchase confirmation page or through an email. If you buy the software from a store, the serial number is usually located on the disc package or case. If you
lost this serial number, you can try contacting the technical/customer support for the product and they may be able to help you obtain a new one. An alternate method is to obtain a product key from online or through a
torrent program. This is usually illegal and sometimes lead to a virus if you are not careful. I will explain more below.
-In some cases you can
obtain a serial key or a
crack program for the software product. A crack program basically provides you with a serial number or it can
circumvent the software authentication process(bypass activation). Be warned, doing this is usually
illegal and if you are not careful when downloading programs or visiting websites, you can potentially get a virus.
An example of how to do this is to use a
torrent site. On a torrent site, you can download a file called a torrent. This torrent basically is a pointer to all the computers who have this certain file you wish to download. You then use a torrent down loader like
Utorrent to open the torrent and download the file. A website you can visit to look at torrents is
piratebay.org.Go to piratebay, search for the file you want to download and then save it to your computer(desktop is easiest). Then open the torrent file in Utorrent. It should start to download the file. I would advise you also download a program called PeerBlock and have that running in the background as you download files. PeerBlock keeps a list of IP addresses(computers) who's intent is to track and prosecute people who download files illegally.
By searching, you may find a
crack program you can use to crack the software in question, and in some cases find a "key generator". A key generator usually provides you with a
serial key to use.
-If you are looking for a serial key for hardware like a laptop or MP3 player, this is usually located on a bar-code sticker on the back, or sometimes in the battery compartment. Also, you may be able to find it within the software by turning on the device and going to "help" or "about'.
I hope this article was informative. Thanks for reading.
Regards,
G33kKeywordsobtain serial key, how to obtain serial key, how to crack serial key, lost serial key, find serial key, find software serial key, find software serial, crack software serial key
Thanks a lot for your help. :-)
