Hello hope you can help. My computer has recently needed a complete repair due to an accumulation of viruses over a period of time. All data was wiped including my micro trend pc cillin anti virus protection. I have managed to use a free service on the internet which will expire tomorrow. Is it possible for someone to check my records and re-instate my protection?? I purchased on the internet and have been a regular user of your service for the last couple of years. I look forward to your response. Many thanks Debra Smith
1 Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2 When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
3 Press Enter to start the Windows Setup. To setup Windows XP now and Repair Install , press ENTER. do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
4 Accept the License Agreement and Windows will search for existing Windows installations.
5 Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
6 Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
7 Reapply updates or service packs applied since initial Windows XP installation. Please note that a Repair Install using an Original pre service pack 1 or 2 XP CD used as the install media will remove SP1/SP2 respectively and service packs plus updates issued after the service packs will need to be reapplied.
Hi, click on this website, you can download the "Microsoft Security Essential; I use it, and "recommend it "highly." Rating the solution is appreciated, thanks." http://www.softpedia.com/get/Antivirus/Microsoft-Security-Essentials.shtml
