I have a Diplomat ADP8352 Integrated Dishwasher which seems to have just stopped working. The on light button comes on but nothing else on the LCD panel works.
Did you get a solution I have the same problem Could it be that I pressed the delay button by inadvertently??Did you get a solution I have the same problem Could it be that I pressed the delay button by inadvertently??
You can't post conmments that contain an email address.
Check the manual and see if it can diagnose the problem. Or you may need to have it checked. http://www.manualslib.com/manual/277803/Diplomat-Adp8352.html
Click the link and the file will open. You can then view save and/or print the manual. If you are unable to open the file, you may also need to download Adobe Reader:
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
My Diplomat ADP8352 when running a cycle it will run for ages, doesn't seem to get hot. If i switch off the m/c then switch it on again it dumps the water left in the m/c?
Hello wayne180764,
If the wash arm ( impeller ) is free to move, then chance are the motor that dirves it isbound up or defective. IT may be trying to spin ( the humming noise) but unable to ( for whatever reason).. and then shuts down from overtemp or overcurrent sensors on motor.. If you want to diagnose the parts further..please use this link which includes some additional information http://www.haier.com/admin/en/product/upload/ADP8352-UM.pdf
