My pen drive shows used space & free space is 0.insert disk in to drive.
What else have you found about this Transcend pen drive in Disk Management or Properties interface? Does it also show as RAW file system there? Or are you asked to format this pen drive before you try to access anything inside?
If so, your pen drive must be logically or physically damaged somehow due to RAW file system, the simple formatting process performed on this pen drive can help fix your disk problems.
But, you also should know that you'd better not format this drive in a hurry when you do left great important data inside. Merely download RAW file system flash drive data recovery software to recover pen drive data back before any format.
But, if this drive is not displayed as RAW, you'd better scan it with antivirus software to see whether it is virus infected.
See if you can format it if not it is bad
insert transend pendrive go to control panel administrive tools computer management disk mangement you you can right click select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
hope this helps
