No it does not. The best you can do is to print CD labels, but you would need a program with software to handle them.
Reference Photosmart B209 Manual
Thanks for using Fixya.
PS. The manual is a large file (13MB) so be patient if you download it..
SOURCE: My photosmart B209 was just hooked up and
A wide range of problems are addressed in the following solution from HP. From what you have stated, try Solution 2, Step 3 - "Determine whether the printer is paused or offline."
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01893322&cc=us&lc=en&dlc=en&product=3777182
SOURCE: HP Photo smart Plus All-in-One B209
http://h10010.www1.hp.com/wwpc/us/en/sm/WF05a/18972-18972-238444-421635-410635-3777155.html
follow the link.. and download
SOURCE: Reset printer cartdrige
CHECK THIS LINK
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01757325&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=3777182
IT MIGHT BE HELPFULL
SOURCE: printing in mirror image
If you look in your manual, it should tell you where the option is. If you can't find your manual, there should be one up online. I did a quick search to find where that option may be, and this is what I found:
In the Printer Features area, select On from the Mirror
Image drop-down list for it to appear as an available option
Like I said, you may need to look in your manual to find out for sure.
Hope this helps! :)
SOURCE: I have a HP Photosmart Plus B209 a printer. The
You are one of many B209 owners with this problem. The B209 has a defectively-designed printhead. The HP site is clogged with complaints about it. The HP customer support chat people will ask you to disassemble your printer in order for you to read them several dates and code numbers. They will then tell you that your warranty has expired and they won't do anything to help you.
If you take your print head out of the printer you'll find a thick, gummy residue of black ink on it. I don't even want to think what that residue cost me with HP ink costing more than most precious metals. You can try cleaning it but the only solution is the purchase of a new print head. Or, you can try my alternative solution:
1. Open window
2. Throw HP B209 out window
3. Order non-HP printer on Amazon
4. Never buy HP again
If HP is going to sell a faulty product then they should stand behind it and make it right. It's clear from my 2 hours chatting with the HP man overseas that HP will not be doing this.
