TV is turned on-only see blue screen that says "Video" I hooked up the cable and need to turn the chanel but nothing is happening. I don't have the remote and it is stuck on "video" how do I get it off "video" so I can see actual chanels
SOURCE: HOW TO SET UP REMOT TO VIDEO CHANEL,I CAN,T CHAN
Hello Audio and Video Front Inputs are available for a quick connection of a VCR, to playback video from a camera or attach a gaming device. Use the AV button on the remote control to tune these inputs. 1 Connect the video (yellow) cable from the Video output on the Camera (or accessory device) to the Video (yellow) Input located on the FRONT of the TV. 2 For Stereo Devices: Connect the audio cable (red and white) from the Audio Left and Right Outputs on the Camera to a Stereo to Mono adapter. Then plug the single end of the adapter to the Audio In (white) jack on the FRONT of the television. For Mono Devices: Connect one end of the audio cable from the Audio Out jack on the device to the Audio In 3 Turn the TV and the accessory device ON. 4 Press the AV button on the remote control to tune the TV to the side input jacks. "Front" will appear on the TV screen. 5 Press the PLAY button on the accessory device to view playback, or to access the accessory device (camera, Repeatedly pressing the AV button on the remote control will toggle the picture source from the current channel, or Front input jacks. Note: The Audio/Video cables needed for this connection are not supplied with your TV. Please contact your dealer or Philips at 800-531-0039 for information about purchasing
gaming unit, etc.).
the needed cables
OK
