I have an LG Fridge with ice & water dispenser. I too had a slight delay each time until the water stopped completely. I had checked the line for leaks but could find no leak until the water started coming out from under the freezer side. The water line under the freezer travelled into the fridge door storage container behind the bins. The line had gone brittle and burst. I obtained new tubing from Endeavour 5/16" and replaced same by feeding from inside fridge door down to the bottom of freezer. The original pipe was 170psi I have replaced with 1000 psi. I will check one a year, my fridge is 2 1/2 years old. Try the line at the back going to the fridge side, ours was loose as it was broken.
There may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
