You need to do a factory reset on these tv's to get it working everytime you power it up. Then you can toggle through the inputs to get it to work. What a pain!!
Turn off blue screen in the menu of the TV if you can or cycle through the input sources on the remote to find the directv signal. Check cable setup in back of TV if it still does not work. Has the directv box been working with any other TV?
0019 = NEC1, device code 4
0054 = RC-5, device codes 0 and 3
0150 = Mits, device code 71
0178 = NEC1, device code 4
0765 = NEC1, device code 64
1256 = NEC1, device code 64
1276 = $0057, device code 71
Toshiba code 678 works for a Polaroid TV model FLM-1514B
Polaroid tv/dvd combo is 1991.
The dvd code equivalent of that code is dvd 1480.
Make and model of your TV would help...thx
The tv was hooked up to the Directv box and working fine, and then one of my children pressed the wrong button on the Directv remote when turning off the tv, and then it wouldn't turn on again. I assume it's a problem with the Polaroid tv(since it's not an expensive tv)and its ability to communicate with the Directv box.
