When the dishwasher drains , there is some water leaking from the bottom ...I think it's the selinoid ???
If it is coming out the bottom of the door (ie around the bottom seal, it may be the dish washing powder. Had this issue on one machine and simply changing back to the one the manufacturer recommend stopped the puddles forming. I think it is due to the power being too sudsy and creating excess bubbles
Check all water hose junctions. If the leak is from hose to pipe, remove and replace. or Use the same hose if sufficient. Discard the old joint area of the hose. While pushing the hose apply little soap for a easy placement on the solenoid. If clips are used place the back!
