First, check to ensure your needle is not bent. If its not bent then just adjust your metal plate at the bottom. Loosen the screws and shift the plate back, tighten the back screw first and see if the needle now passes the plate. If not make some more adjustments. Once the needle passes the plate properly, tighten the front screw. Hope that helps.
