{SW1}---Light 1 switched leg to fixture 1
HOT wire (Line or Feed)----{
{SW2}---Light 2 switched leg to fixture 2
The wire supplying power to the switches will be connected to the "LINE" terminals tied together with a breakaway tab (common feed). The upper "LOAD" side terminal will output to the first light and the lower "LOAD" side terminal will output to the second light. The neutral (White) wires if present will be joined together (wirenut).
All electrical work should only be done by qualified individuals.
I need more info. Do you have two light switches like the pair pictured? Does the switch box have three sets of wires? (Each set having a black, a white and a bare wire.)
Need to know if just regular lights, 2 wires?
