I cannot change my wallpaper
Instructions
Step 1
Click on the Start menu button. Then click on Settings and then on Control Panel.
Step 2
Double-click on the Display icon or text link. This will open a window named Display Properties.
Step 3
Click on Background if that tab is not selected. Click on one of the items that appear in the box labeled Wallpaper.
Step 4
Inspect the preview that appears above the Wallpaper menubox. Use the Display menu to the right to experiment with tiling, stretching or centering the picture that you are previewing.
Step 5
Click on Browse to use an image stored elsewhere on your hard drive. Locate the image and click Open.
Step 6
Click OK to change your background, or wallpaper. Click Cancel if you decide to maintain your current settings.
Tips & Warnings
For background pictures, you can use scanned or digital photographs, an image downloaded from the Internet, or perhaps some original artwork that you created in a graphics program. Graphics files suitable for use typically end with extensions of .bmp, .gif, .jpg, or .tif.
Wallpaper consisting of large image files will consume memory and system resources. Consider using a small image and tiling it if resources are scarce.
Please give the positive feedback. Thanks for using Fixya.
Anand Kumar
First you need to create a desktop.ini file in your flash
drive.
Open Notepad and click Save as.
Then set file name to desktop.ini and change Save as type to
All files.
Click Save as.
Place your wallpaper in the flash drive. It should be a
".jpg" file
Open desktop.ini file from your flash drive. Copy and paste
below code to it.
Last line of the code, you can see
"IconArea_Image=wallpaper.jpg". Replace "wallpaper.jpg" with your wallpaper
name.
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC}={BE098140-A513-11D0-A3A4-00C04FD706EC}
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
Save your file. Unplugged the flash drive from PC and plug
it again. That's it.
If you need more information
Visit SmartUSB.net
Add wallpaper to your flash drive background
http://www.smartusb.net/p/add-wallpaper-to-flash-drive-background.html
Change your flash
drive icon
http://www.smartusb.net/p/change-flash-drive-icon.html
Insert symbols to your flash drive label
http://www.smartusb.net/p/insert-symbols-to-flash-drive-label.html
Hide a file or folder in your flash drive
http://www.smartusb.net/p/hide-file-or-folder-in-flash-drive.html
Change font color in your flash drive
http://www.smartusb.net/p/change-font-color-of-your-flash-drive.html
