Question about KitchenAid KCMS185J Microwave Oven
Always on My KCMS 185 JBL-3 microwave is always on, unless you open the door or unplug it. The door switch seems OK, since opening it will turn on the light and shut it off, but as soon as the door is closed, it starts operation (the plate won't turn unless you set the timer)
  • KitchenAid Master
  • 3,740 Answers
Most probable failure is this VERY expensive part:
http://www.appliancepartspros.com/part_details.aspx?part_id=4327040&image=1
This is what controls the Magnetron operation via the relay on the PCB. If the Magnetron is operational without programming it usually is the cause of the problem.
I would recommend that all wiring to the control board be verified before considering replacement of the board. The price of the board to me is off the charts in cost! Not sure what the original purchase cost was but the price of this board would make one consider unit replacement vs component replacement when you add in the cost of the service call.
I am sure this is not what you wanted to hear.
Thanks for using FixYa,
Kelly
Posted on Apr 12, 2010
6ya staff
SOURCE:
KitchenAid microwave oven model kcms 1555. The button for the door does not have any tension as a result the door will not latch close, light will not turn off
It sounds like the door spring had broken. Take the covers off and it should be apparent what had happened. It may be a part you can get at the hardware store or it may be an OEM part.
Sep 03, 2018 | KitchenAid Microwave Ovens
Why won't my interior microwave light turn off and my microwave won't start?
It sounds to me that your door switches aren't working.Your oven is protected by a couple of switches that engage when you open or close the door.They control a couple of safety features and also your interior light.One of them seems defective.
Dec 17, 2014 | KitchenAid Microwave Ovens
Hotpoint Microwave Model RVM1435BD 001- microwave comes on when I open the door.
Many microwaves have similar issues. Usually, (not always) only the light is on and the fan is running, not the section that produces the microwaves. This problem can be caused by the door switches that are out of alignment or a defective control board.
Nov 14, 2017 | Hotpoint Microwave Ovens
I have a GE Spacesmaker model #JVM1440BH04 that came on by itself and can't be shut off unless the door is opened. It does not seem to be cooking since nothing heats up unless the cook start buttons are...
The problem is in one of the door switches, "it is defective" this is a highly dangerous situation and should be checked immediately, the microwave oven should unplugged until a appliance repairman looks at it.
Jan 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Off/On is switched
Talk about vice versa? Well it should be the exact opposite. It MUST have a microprocessor fault, unless someone swapped the wires... You will have to get it "looked at" this is a weird one.
Feb 15, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
Microwave will not stop cooking unless I open door
you have a bad door switch call a tech these things can kill you even if they are unplugged.
Jan 07, 2010 | Amana MVH210W Microwave Oven
My Dacor DMT2420 fan, light and turtable motor run continuously when the door is open. I have unplugged the unit to reset it with no help, another on-line forum expert suggested checking the door switches...
If the cooling fan, light and turntable run continuously when the door is open, but not when it is closed, your secondary interlock (bottom door switch) is shorted (always on).
Even if it's shorted, the actuator button (usually red) will still move up and down when you open and close the door.
It will need a new door switch.
See the service manual here. See our file on door switches here.
Jan 04, 2010 | Dacor DMT2420SS Microwave Oven
GE Microwave Oven would not shut off even when the door was opened. We unplugged it and plugged it in later and now it seems to be OK. What happened?
Hi, the contacts in the micro switch or relay proberbly fused together. Do not open door if is still on unless you want to cook yourself
Aug 04, 2009 | Microwave Ovens
Danby microwave m # 1153
danby dmw11536 my microwave oven start beeping all the time. i can start it if ipush the cancel button, ordinarely once but sometimes it won't start unless you unplug it. also disylay shows 1:00 but keep time of cooking anyway. after it returns to beeping all the time, sometime you have to leave it unplugged for a couple of hours. danby dmw11536
Aug 27, 2007 | Microwave Ovens
KitchenAid KCMS185J Microwave Oven Logo
159 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
