American Standard 2770.018w.020 Cadet Whirlpool White Logo
Posted on Apr 12, 2010
The jets in my whirlpool aren't working. Any suggestions? The just on the right side of the tub are working at full blast but the left hand side is not. I have adjusted both sides, but the left is barely functioning. I purchased the whirlpool cleaner but it simply did not help. Prior to the purchase, I have been cleaning the jets with bleach.
5 Related Answers
Anonymous
  • 14 Answers
  • Posted on Dec 27, 2008
SOURCE: Not all jets working on Hydrosystem Whirlpool Tub
I believe the below web site can help you with your problem. The jets are more then likely just turned off.
I hope this helps.
sanray
http://www.hydrosystem.com/hydro4/options/components/
Anonymous
  • 125 Answers
  • Posted on Feb 24, 2009
SOURCE: my whirlpool bath tub has three jets that work & 3 jets that are
The suction IS the water intake. it takes the water from the tub into the pump and the water comes back out through the jets.
Donni Steen
  • 687 Answers
  • Posted on Mar 31, 2009
SOURCE: We have purchased a whirlpool tub model #
Some jets you can stick your finger into the jet its self and move it in 360 degrees. Others have a notched round trim piece that when turned counter clockwise, will loosen the jet where you can manipulate it as described above. You will need to retighten it after your done so it doesn't end up the same way. If you have trouble, you may want to use a little spray lubricant on it so it will loosen.
snap101
snap101
  • 117 Answers
  • Posted on Jul 29, 2009
SOURCE: can you cap off the jets of a whirlpool tub if you
you can but it's not worth the trouble of doing it! lots of fiberglass and you need to have access to the whole tub on the sides
Anonymous
  • 86 Answers
  • Posted on Mar 20, 2010
SOURCE: Whirlpool tub jets aren't working
This seems to me that the motor is separated from the turbine blades. Either the plastic union cracked or stripped. Most likely stripped.
Purge line
The breaker the manual is referring to will be the main circuit breaker at the panel.
If the system is not running the purge cycle as it is supposed to and turning the power on and off does not reset the control box then it is likely that the control box has a bad part in the circuity and should be replaced.
Rod
US Parts Center
Apr 13, 2014 • Maax Home
Galbocca bathtub with jets
I have galbocca jet tub which is no longer working. I live in Lawton, ok. No one works on them here. Any suggestions?
I am interested in the Eljer Gibraltar tub. What does the AFR stand for? Also, what is the correct part no. I would need to order to get a tub with the drain and overflow on the left side as you face the...
Right hand and left hand refer to where the drain is located to where you are standing in front of the tub.
if you are standing in front of the tub and the drain is on your right hand then it is considered a right hand tub.
2helpful
Whirlpool Jacuzzi with 10 jets one stopped working.
either one of ur hoses has come off or is stopped up get to the sides and see if one has come off
Several jet vents have hardly any flow coming out
These tubs often have an adjutment on them that control how hard the jet blows. You may have to adjust them. There isn't anything that can get into the lines that will clog them so I can't think of anything else it could be.
Heater problem on my BMW 318ti compact
the heater resistor pack also known as the hedgehog, located under the steering coloumn, on the left hand side ( right hand drive car)
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
