I have a acer travelmate 2451 and I can not get it to power up.
I took the battery out then unplugged the computer then pushed the power button for 30 seconds. plug computer back in pushed the powere button like I was told to do but it will not power on, it does not show windows. No light just bank screen.
That sounds like a power ribbon issue to me as well. I would suggest you get a certified technician to look at it unless you are knowledgeable with computer parts.
If the computer doesn't power on what-so-ever, it may be your power ribbon. I have the same issue with my Dell Inspiron 15.
The power ribbon on your motherboard connects to the power button on your laptop which obviously turns on your computer.
That may have been damaged. I suggest taking apart your computer and trying to find out the issue from the inside. (Or, if you don't know how turn it in to a technician.)
SOURCE: acer aspire 4330 will not boot up
Can you plug a external monitor into the machine, most laptops have that serial port. If montor comes on, you have bad display or connections, If not you have problems with laptop....Good luck
SOURCE: Acer Aspire 5920 will not boot at all...
The power button may not work, that is most common in laptops, or you have a short.
Testimonial: "Exactlt what I had been thinking!"
SOURCE: my acer travelmate will not boot up, please help
Well I have the same problem, I think it is a BIOS problem because after the acer screen it says Windows did not start succesfully. I saw start Windows normally but it has that "blink of an eye flash" as well, then it goes back and tries to boot up again. Maybe take it to a shop to get fixed.
SOURCE: Hi all. I need to reset my acer travelmate 2451
You could try to do a system restore to a date near to purchase. It is normally under start --> accessories --> system tools. Backup all your data before doing a system restore!!
Cheers
SOURCE: My Acer Aspire 5315 wont turn on?
remove the battery then try to turn on the laptop. if this works you probably have a bad/shorted battery
Do any lights come on at all to indicate there is power coming into your notebook?
