Bunn 10 Cup Home Coffee Brewer Logo
Posted on Apr 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Coffee maker is leaking
Purchased this appliance in 2008 it is leaking from the bottom. I read the complaints and find this is a commom occurrance and I am disappointed.This is my second one and just replaced the other because it was older. I would really like to have another pot. Can you help. I also read that the gasket kits do not stop the problem.
I am in Baton Rouge, LA.
Anonymous
Level 2:
  • Expert 131 Answers
  • Posted on Apr 13, 2010
Anonymous
Expert
Level 2:
Answers
131
Questions
0
Helped
104079
Points
301
This unit is under three years old, so phone Bunn (you can get the number for customer support from www.bunn.com). They should replace this unit for you under warranty.
2answers
I purchased a Kenmore Elite Coffee maker last year and now water is leaking from the bottom. I noticed it has a five year warranty on it . how do I go about getting it replaced or repaired?
Claim using this phone number. It says 2 years warranty, but the product link does say 5 years.
WARRANTY SERVICE
To obtain the warranty coverage stated below, return defective product with proof of original sale to Kenmore (Transformco) authorized retailer from which it was purchased. Call this number to obtain the warranty coverage stated below: 1-800-265-8456
KENMORE LIMITED WARRANTY
FOR TWO YEARS from the date of original sale this appliance is warranted against defects in material or workmanship when it is correctly installed, operated and maintained according to all supplied instructions.
WITH PROOF OF ORIGINAL SALE a defective appliance will be replaced free of charge. If replacement is not available, the retailer will provide item price credit usable for other purchases from that retailer.
This warranty does not cover expendable parts that can wear out from normal use within the warranty period.
This warranty is void if this appliance is ever used for other than private household purposes.
Kenmore Elite Brew Coffee Maker with Burr Grinder
Koolatron https://www.koolatron.com > en-ca > products > kenm...
Kenmore Elite Grind and Brew Coffee Maker ; Power Type, 120 Volt ; Product Weight, 11.50 lbs (5.29 kg) ; Color, Silver, Black ; Warranty, 5 year limited warranty.
$319.00 · ‎In stock
Kenmore Elite Programmable Coffee Maker ' 12-cup
Koolatron https://www.koolatron.com > products > kenmore-elite...
Best of all, Kenmore Elite products are backed by a 5-year limited warranty for your peace of mind.
1helpful
Leaking underneath
You are not alone having the water leak in your SS-700. For better understanding what caused that leak please read the review on Cuisinart SS-700:
http://www.cuisinartfoodprocessordeals.com/cuisinart-ss-700/
2helpful
Mr. Coffee CG13 12-cup coffee maker. Have used it
There is high temp tubing that may have come loose or become dammaged fromheat or the coil that heats the water may be leaking if you are using strong cleaning chemicals to remove scale from the unit. The bottom is held on with screws. Remove these and look to see what is the source of the leak.
Water leaks
unds like there is a leak in the tank. Take it back for a refund/exchange.
Water leaks out from underneath coffee maker
Well they don;t give these away for sure. Lets see if we can help you out. ? are you over filling it.This happened to me because I was reading the fill line wrong. {got new glasses} . If not may be you could try makeing less. But if only 1/2 cup comes out and no more, that wouldent indacate a leak in the tank, if there was it would all leak. Try backing off on the coffie and water, and see if it still leaks. if it does get back to me. DFD
7helpful
Water leaking
The silicon seal inside the coffee maker tends to disintergrate. Bunn Inc. does not sell parts for the inside of the coffee makers, but a seal kit can be purchased through a small appliance repair center or repaired for a small cost. Kit is about $8.00 at most places.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
