The error message is "machine trouble call service (COF32)
COF32 means the ATDC sensor has detected some unusually high or low readings.
The ATDC sensor measure the toner lever inside the developer unit.
Try swithcing on/off, open/close the front door to clear the code.
If this doesn't work, you'll need an engineer to reset the ATDC level.
Good luck
Tam
I have a bizhub 211 and when i try to print it gives me an error saying 1st cover paper jam,when there is no paper jammed. I have checked the paper tray and side cover.When i print an A3 copy it works perfectly.Can anyone help please?
My biz hub 211 writes machine trouble
Call 0502 and then switches off automatically
