SOURCE: Wheel shaft seals on troy bilt pony 7 hp.
If the seal fits over the axle shaft it should be ok. be sure your axles are very clean as not to ruin the new seals when applying them. probably a good idea to replace them as a pair (right and left side) to save you time down the road.
SOURCE: belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
SOURCE: how do i adjust belt on troy bilt horse tiller
Go to www.troybuilt .com and download or view an owner's manual.
SOURCE: how do i put a troy-bilt tiller 3 hp.into free
Knife333 is right, the hub pin method he described is the only way to disengage the wheels. The gearbox is not designed to be shifted in/out of gear, it is engaged full time. Foward and reverse movements are controlled by the drive belt direction only.
