You can download Scanner Driver from this site.
SOURCE: Installation of CanoScan Lide 25 Drivers
Hi please follow link bellow to download drivers for you scanner
http://software.canon-europe.com/products/0010219.asp
please dont forget to leave fixya feedback
Regards Alan (alstech)
SOURCE: Canoscan Lide 30 compatibility with Windows 7.
There are no official drivers for CanoScan Lide 30 for Windows XP, so your problem is obvious. I suggest you sending an e-mail at Canon including details about your scanner (date purchased, serial number in text form or scanned) asking them to develop driver set as this model is very trade and at shops since 2006 or 2007.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
SOURCE: driver for canoscan lide 35 for windows 7, 64 bits
this is the support site ...and the driver I found there is for windows 7 but on 32..Cause they do not have one for 64 bits OS yu should download and try the Vista one on 64 ..cause the compatibility is usually high and it s worth give it a try ..If not the only way you will be able to use is if you reinstall the windows & on 32..You will not feel much difference but the driver's compatibilities will be easier to match
SOURCE: CanoScan LiDE 25/LiDE 60 compatible with Windows 7?
Yes it is compatible with windwos 7.
Click here
Click on above link wait for 3 minute then select your os win7 then wait again then download driverr and patch update for it then install in computer then you can use it.
Let me know if you need further assistance.
Thanks for using FixYa.
Guide to installing Canon CanoScan LiDE 35, 50 and 60 on Mac OS X 10.8. Mountain Lion:
FIRST PART: DELETING OLD LiDE DRIVERS AND SOFTWARE
HD:/Library/Image Capture/Twain Data Sources
delete the CanoScan CanoScan XXXX.ds file
(Make note of any other files that may be in this folder. If other files are present, move them to the desktop for now. Then place them back after successfully using the scanner.)
HD:/Library/Preferences
delete the 'CanoScan XXXX' folder
HD:/Users/Shared
delete the folders containing the name CanoScan, or starting with CNQL.
HD:/Applications
delete the CanoScan Toolbox Application
HD:/Users/YOUR-MAC-USERNAME/Library/Preferences
delete any items named "CanoScan Toolbox"
SECOND PART: MAKING YOUR SCANNER WORK
CanoScan LiDE 50 and LiDE 35 work both with the 35 driver:
lide35osx7721en.dmg
CanoScan LiDE 60 driver:
lide60osx11131en.dmg
VueScan Software:
http://www.hamrick.com/#download
VueScan 9.2 (or later) x32 for Mac OS X
Alternative to VueScan: CanoScan Toolbox. I prefer VueScan.
Try your luck with Version 4 or Version 5.
CanoScan Toolbox 4: cstbosx4934ej4.dmg
CanoScan Toolbox 5: cstbosx5014ej4.dmg
(Alternatively try and install CanoScan Toolbox 4 or 5)
