I have a Samsung HL-P6163W, hooked to dish network hd receiver with HDMI connection. The color wheel went bad about a year ago, very shortly after I bought it used. I then noticed that in darker pictures and facial tones were blotchy and not blended, causeing these areas to be blury. This may have been going on before the color wheel replacement but thought it was part of the color wheel problem. I was recommended by a tv tech after looking at the tv to replace the digital board because the problem accures on all inputs. So I just had that done and still have the problem. Any suggestions?
Fire the TV Tech! Your problem is the adjustment to the color wheel timing. To correct this: With TV OFF -> on remote, press MUTE, 1, 8, 2, POWER. The TV will come up in service mode: ( Left / Right arrow keys for item selection, Up / Down to change values, Menu to return to previous menu, Power to exit Service Mode)
Enter the submenu of item 1. DDP1011. Now, adjust item 4. INDEX DELAY to correct the "clay facing" problem you are having . Default value is 47.
You should have a "problem" image paused to check you work if possible. I hope this was of some assistance, best wishes.
Hi my name is Mike Houston of DISH Network and I see you want to connect your HDMI cable to your 511 DVR receiver. To have capability for your HD TV you will need to have a VIP HD series receiver, I will be more than happy to assist you with this and you can contact me at [email protected].
