When press the start button and the TV won't turn ON. The standby/timer light keeps blinking. Sometimes it starts after a few try and most the time it takes forever.
U know how to solders?U have a high voltage problems,it a big black block of plastic with a red wire with a cap hook to a CRT(tv tube).Resolders that FBT,the flyback transformer,should solved this.Not than the FBT must replaced,because it shorted.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Yes....this blinking code is a diagnostic fault code which is a good thing, you count the number of blinks and it tells you where the problem is.....you also can see it by pressing the buttons, DISPLAY,CHANNEL,5,volume - not + ,then power....In your case it blinks 5 times,its in the video out,you need a desoldering iron,solder,rosin core 60%tin and 40%lead...remove and replace these,Q761,Q705,Q732 on the C board also Q218,Q219,Q220 on the A board.hope this helps.......
The Sky+ remote should automatically default to Sony TV's. Leave the batteries out for a few minutes and try again. The Code for Sony is 0000.
Or try this :-
With TV and sky box on.
Press the 'TV' button on the remote.
Hold down the 'select' and the 'red' button (of the four coloured buttons) together, until the red light on the remote blinks twice. (takes 2 seconds)
Press the 'TV' button again.
Now enter four zeros, the red light on the remote should blink twice.
Press the 'standby' button (top right).
If the TV turns off, then press 'select' and the light should blink twice again, job done.
If the TV does not turn off then press 'TV' followed by 'standby' again.
Alternate pressing 'TV' 'Standby' until the TV turns off.
When it does, finish by pressing 'Select.
Check the red light on the remote, if it blinks 3 times, then it has run out of options for 0000.
Setting the ON time (Example: AM 10:15). 1. Press the TIMER button on the Unit for more than two seconds. The Timer indicator lights up and the hour digit of the current ON time blinks on the display. • When the clock is not set, “CLOCK” and “ADJUST” appear alternately on the display. Set the clock first. Press the ¢ or 4 button on the Unit to set the hour you want the Unit to come on. Pressing the ¢ button moves the time forwards and pressing the 4 button moves it backwards. Hold down the button to move the time rapidly. 2. Press the TIMER button. The minute digits of the ON time blink on the display. Set the minute you want the Unit to come on, using the ¢ or 4 button. 2 Setting the OFF time (Example: PM 1:30). 1. Press the TIMER button. The hour digit of the OFF time blinks on the display. (The same time as the ON time will be automatically set.) Set the hour you want the Unit to be turned off, using the ¢ or 4 button. 2. Press the TIMER button. The minute digits of the OFF time blink on the display Set the minute you want the Unit to be turned off, using the ¢ and 4 buttons. 3 Selecting the music source. 1. Press the TIMER button. The “TUNER” or “CD” blinks on the display. 2. Press the ¢ or 4 button to select the music source you want to listen to. The display changes as shown below. TUNERôCDô(back to the beginning) 4 Setting the volume level. 1. Press the TIMER button. The current volume setting blinks on the display. 2. Press the ¢ or 4 button to select the volume level. -- :The current volume level will be used. 0 to 50 :When the timer is turned on, the Volume will be automatically set to the selected level. 5 Press the TIMER button. The timer setting is completed and the display returns to the display before you set the Timer. The Timer indicator remains lit. 6 Before turning off the System, prepare the music source selected in step 3. TUNER: Tune in to the desired station. CD: Insert a CD. (Playback will start from the first track at Timer on.) 7 Press the % button to turn off the System. In standby mode, you can see the Timer indicator ( ) on the display. • When the timer turns on, the Timer indicator starts blinking and the prepared source in step 6 will be played. To cancel the timer, press the TIMER button. The Timer indicator ( ) goes out on the display. To re-activate the cancelled timer, press the TIMER button to light the Timer indicator ( ). At this time, you can see the current timer settings. Each setting appears on the display for two seconds in the order of ON time, OFF time, music source and volume. To change the timer setting, repeat the setting procedure from the beginning.
If the TV turn itself off then perform the following steps:
(i) Check if the Sleep timer is activated.
(ii) Check if the Parental Guide prohibits viewing during that time and/or limits amount of viewing time per day.
(iii) Check the batteries on your remote, low battery power may cause random signals from the remote.
(iv) Disconnect all the cables from the TV then reconnect them after a few hours.
(v) Ensure the power cord from the TV is directly connected to a functional wall outlet.
(vi) You may also try resetting the TV to the original factory settings by pressing the Reset button on the remote control supplied with the TV when in Menu.
The following is the information indicated by the blinking patter of the standby/timer lamp on the TV:
2 times : Power does not come on. Load on power line shorted.
3 times : The TV has entered standby mode.
4 times : Has entered standby state after horizontal raster. Vertical deflection pulse is stopped. Power line is shorted, or power supply is stopped.
5 times: No raster is generated. CRT Cathode current detection reference pulse output is small.
6 times: No picture
9 times : No sound
Furthermore, the TV is equipped with a self-diagnosis function that you can use to determine whether the issue is related to any hardware malfunctioning. Perform the step given below to run self diagnosis:
Quickly press the remote command button in the following order from the standby state.
Display -------> Channel 5 ---------> Volume -(minus) --------> Power ON.
If the Self Diagnosis display numeral "1" for any parameters then a fault has been detected and service will be required.
Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
