Question about SanDisk 2GB microSD Memory Card
Fix mirco sd card - SanDisk 2GB microSD Memory Card
  • 493 Answers
To fix your micro-sd card you can use the program which you can download by clicking here.
After downloading the file run it in your PC and format your micro-sd card. Windows file manager can not read the card but this software exactly can format it. But if you format the micro-sd card all the file in it will be deleted.
Do the followings to format it:
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file in your PC.
You will see the menu below:
- Select the device which you will format.
- Select the file system FAT32,
- Give a volume name.
- If it is checked uncheck the quick format option. And the other options will be unchecked.
- Click the Start button to begin formatting.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Posted on Apr 12, 2010
  • 1 more comment
  • Ibrahim OKTAY
    Ibrahim OKTAY Apr 12, 2010
    NOTE: If you can not manage to download from the link which I gave you above, please try to download that file by clicking http://dl05.chip.eu&f=/16863/HPUSBFW..." target="_blank" rel="nofollow" >HERE.
    Thanks.
  • Ibrahim OKTAY
    NOTE: To download the file on the opened web page, see the picture below:
  • Ibrahim OKTAY
    Ibrahim OKTAY Apr 14, 2010
    NOTE 2: Sorry for this extra note. I created my own site for you to be
    able to download the files easily which I uploaded for you.
    Because the other linked web pages may have troubles and need extra
    explanations.
    Now you can easily download the file from here
    that I mentioned in my previous messages.
    Thanks.
SOURCE:
I NEED TO VIEW WHAT IS ON MY MIRCO SD CARD WHEN I PUT IT IN THE COMPUTER NOT CAMERA WHAT ACCESSORIES DO I NEED TO DO THIS FOR THE COMPUTER TO VIEW WHO HAS BEEN IN MY HOUSE
well not many pc's have Micro sd card ports , so id say u need to start there , buy a usb to mirco sd card reader (there less than 20 dollars) and then install the drivers that come with reader , then its all up to windows (assuming you have windows) it should see that u have properly connected the reader and then ask you via a pop up what you would like to do with the new drive, of course u select "view files" depending on what put the files on the card it should be in a directory already (name can be numbers or letters?) click on this and u should see your files or photos on there
Aug 17, 2016 | Cameras
Will sandisk mirco sd cards work?
You didn't buy a microSD card at all, you bought a microSDXC card.
The Eclipse 180 works with microSD cards (2GB or smaller) and microSDHC cards (32GB or smaller). It does not work with microSDXC cards.
Jul 26, 2014 | Mach Speed Eclipse 180 MP3 Player
Mirco SD card shows free space 0 bytes and used space 0 bytes
Click on the drive and then in windows select tools then folder options, then view and select or unselect hidden files or folders, plus hide protected files.
This should show all files on the card.
The only other thing I can think of is that the camera uses a different format to Windows. So it can't read the card.
Jun 07, 2017 | SanDisk Electronics - Others
I added a 2gb mirco SD card to my Sansa e270 6.0gb player, but the memory is still only showing 10mb of the original 6.0 gb available for use. How do I get the Sansa to recognize and use the 2 gb mirco SD...
Hi,when you purchase a new micro SD card before use, youwill need to format the memory card so that you will be able to know the actual size of the Micro SD card by checking the details after formatting it.
After formatting the micro SD card and checking the details, if you still do not see the accurate size which is about 1.88mb or the about, that means the micro SD card you bought needs to be replaced. Not a good one.
Have a nice day.
Feb 18, 2011 | SanDisk Sansa e270 MP3 Player
Pls sir i lock my memory card with password, unfortunately i forget it pls help me out because i have an important things inside
Hi if u have a password on the mirco sd card on your phone the password is only only on the phone not the sd, so you can take the card out of the phone. and put it into a mirco SD card to usb adapter
http://cgi.ebay.com/Micro-SD-TF-M2-USB-adapter-card-reader-up-16gb-/220718102304?pt=PCC_Drives_Storage_Internal&hash=item3363d2f720
put it into your usb on ur pc and take all the files you want off. then you can do a master reset on your phone to reset all the setting on you phone and then u can put the sd card back into ur phone
Jan 15, 2011 | Nokia 5130 Cellular Phone
Why cant i put music on my lg env3 from my mirco sd card?
You can, just hook your phone up to your computer vie USB cord. When hooked in, open phone go to 9. Settings & Tools then 2. Tools then 9. USB Mass Storagethis will connect the mirco sd card. PC under My Computer>removable drive open you should have folders listed go to My_Music, drag your mp3's to that folder. If using a Mac it needs to be a new Mac to recognize the mirco sd card, do the same steps as above and the mirco sd card will show up on the desktop as a drive.
jh3:16
Jan 20, 2010 | LG enV3 VX9200 Cell Phone
How to download photos from my LG phone to my
You can, just hook your phone up to your computer vie USB cord. When hooked in, open phone go to 9. Settings & Tools then 2. Tools then 9. USB Mass Storage this will connect the mirco sd card. PC under My Computer>removable drive open you should have folders listed go to My_Pix, drag your .jps from/to that folder. If using a Mac it needs to be a new Mac to recognize the mirco sd card, do the same steps as above and the mirco sd card will show up on the desktop as a drive.
jh3:16
Oct 19, 2009 | LG enV3 VX9200 Cell Phone
It won't recognize the sd card adapter for mirco
THERE is a tweak with the cards you insert on your picture mate, to be honest these things dont recognize memory cards that are above 2 gig. they also dont recognize some brands. the most compatible as per experience is sandisk
Jun 23, 2009 | Epson PictureMate 500 InkJet Photo Printer
SanDisk 2GB microSD Memory Card Logo
542 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
