Hotmail is a free online email service provided by MSN. Hotmail users can create contact lists in their email accounts, which allows them quick access to the contact information of their friends, families and co-workers. The contact lists can be easily changed, contacts can be added or deleted, information can be updated and certain contacts can be designated as favorites. Contact favorites are listed on the inbox menu for easy accessibility when composing emails or instant messaging.
Log into your Hotmail account using your Windows Live ID. This will open your Hotmail inbox. Click on "Contacts List" in the left-hand menu. Click "New" to add a contact to your list. Type in the contact's name, nickname, address, business information and phone number. You can also add other information, such as a person's birthday and personal notes. Click "Save." Your contact list will be immediately updated with the new contact's information. Delete a contact by checking the box next to his name. Click "Delete." Click "OK" to confirm that you wish to delete this contact. b> How to Change Hotmail Contact Information b> Log into your Hotmail account using your Windows Live ID. This will open your Hotmail inbox. Click on "Contacts List" in the left-hand menu. Check the box next to the contact whose information you wish to change. Click "Edit." Modify the contact information. Click "Save" to update the contact's listing. b> How to Create or Delete Hotmail Contact Favorites b> Log into your Hotmail account using your Windows Live ID. This will open your Hotmail inbox. Click on "Contacts List" in the left-hand menu. Check the box next to the contact that you would like to make a favorite. Click "Categories" from the top toolbar. Pick "Favorites" from the drop-down menu. The contact has now been added to the Hotmail favorites list. Delete a contact from the favorites list by clicking on "Favorites" in the left-hand menu. Click the highlighted star in the contact's information box. The contact is removed from the favorites list. Hope this helps.
You only lose an email adress if its specific to your ISP internet service provider the favorites is part of your browser IE: google or ie8 or 9 you will not lose your live or hotmail email adress
I unfortunately do not use internet explorer nine, but you can give this a quick whirl. If you're using windows XP, go to C:\Documents and Settings\Your User Name\Favorites, and verify your favorites are still there. If they are, you should be able to click the drop down menu in the favorites menu (in internet explorer) that says "Add to favorites", on the drop down menu should be import / export. You can import your favorites folder from there.
If you use windows 7 or Vista the folder is C:\Users\Username\Favorites, and everything else should be the same. Hope this helps!
Make sure that you are logged into msn. Since you cleared your cookies and temp files, it may have "forgotten" your login information. Also, check that your browser isn't set to clear history and cookies after you close it.
Click Start
Click Run
Type CMD
Press ENTER
Type CD \
Press ENTER
Type CD user name (whatever your 'user name' is)
Press ENTER
Type CD Application Data
Press ENTER
Type CD Roaming
Press ENTER
Type CD MSN6
Press ENTER
Type DIR /A
Press ENTER
You should see your "favourites" file, and maybe a few others.
Enter CD ..
Press ENTER
Enter RMDIR /S MSN6
Press ENTER
Enter 'y' to confirm that you want to delete the 'MSN6' folder.
go to View In IE----> Select Toolbards---->Click on the option Customize-----> a new window appears showing the tools or option to be added or removed (try to see whether favourite option is present them and try add to them...)
go to start, control panel - click add remove program, on left side see add/remove windows components left click mouse , you will see windows components wizard- scroll - down uncheck msn explorer , click next, ok your msn will uninstall from your program, ok good try , FixYa
Are you using internet explorer (IE 7)? or you are using the internet explorer with an old version. If your internet is unable to load some website you may need to restore its settings. but before doing it, you need to export your favorites first.
1. Open internet explorer then go to file then export your favorites.
2. Click on Tools then internet option, the go to Advance tab
3. for Internet explorer 7(newer version) click on reset. Restore for old internet explorer version.
