Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
Posted on Apr 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where are my less than and greater than signs on my TI-84 Silver Edition calculator?
Anonymous
Level 3:
President:
  • Master 3,278 Answers
  • Posted on Apr 12, 2010
Anonymous
Master
Level 3:
President:
Answers
3278
Questions
0
Helped
784665
Points
9440
Hello.
The less than and greater than signs are above the "(" and ")" keys.
Hope this helps.
Cant find ! button
There is no such thing as a TI89 Plus Silver Edition.
If you mean the TI-89 or TI-89 Titanium, press diamond / (the diamond key below the 2ND key, then the divide key).
If you mean the TI-83 Plus Silver Edition or the TI-84 Plus Silver Edition, press MATH left-arrow 4 .
How do you use the equal sign on the ti-84
The equal sign of the TI83/84/Plus is a relational operator like less than , greater than, less than or equal to) You use it when you are testing if two values (numbers, expressions, or matrices) are equal.
For example, if in one your programs what you do at a certain time depends on the equality of two expressions, you test the equality by a statement :
If A=B do this action.
3helpful
On my Y= menu, Y1 has a greater than or equal to sign instead of = also, at the bottom of my screen an equals sign, a less than or equal to, a greater than, and a greater than or equal to, are lined up
You are running the application called Inequalz. You must uninstall it (NOT DELETE) to return to the normal calculator configuration.
Press [APPS]. Scroll down to find Inequalz. Highlight its number in the list and press {ENTER]. You will see a screen Inequal Running and
  1. Continue
  2. Quit Inequal
  3. 3:About.
Press [2:Quit ..]
Your calculator will unload it out of memory.
Hope it helps.
How would you enter the following equation to graph on a TI-84 Plus Silver Edition calculator? 2 <= t <= 9
To enter the inequation you split it into two inequalities
Graph is as follows
Use [2nd][CATALOG] to access the relaional operators less than or equal, greater than or equal, and the operator AND.
To access the inequality signs scroll upwards from abs( to reach the bottom of the catalog.
Note: You can use t as variable only in parametric graphs. Use x.
Hope it helps.
7helpful
2answers
I do not know how to find the greater than and equal to sign on the ti-84 silver plus calc
press 2nd, then math. It will bring you to a menu with =, not equal, >, <, and that kind of stuff
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
