How to set up your scanner so you can at least listen to it? i don't understand what the hold, scan, function and program button buttons do. I guess i just need help setting it up. thanks
The HOLD key lets you freeze the scanner on an active channel. For instance, if the scanner stops on channel 3, and there's a lot of action there. you can press HOLD to lock the scanner on that channel until you press the SCAN key. Repeatedly pressing the HOLD key will manually advance the selected channel.
SCAN releases a HOLD asnd will also take the unit out of PROGRAM or SEARCH modes and start it scanning the frequencies that you've programmed.
FUNCTION selects the secondary (lower) function of a key. For example, pressing FUNCTION and then the E (ENTER) key will switch the scanner to Pgm (Programming) mode - which lets you enter and store frequencies into the unit's memory so that you can scan them later.
All keyboard functions are explained in detail in the scanner operating manual, which you can download/print here:
http://www.uniden.com/pdf/BC92XLTom.pdf
For a comprehensive database of active frequencies in your area, along with a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Testimonial: "This information was very helpful and your program is excellent!! thank you."
