Question about Razor E100 Electric Scooter
My electric scooter turns on but the throttle doesnt work! any info ? :)
    New Friend:
  • 38 Answers
Replace the throttle. The throttle in these scooter are very cheap and wear out quick. You can find a throttle replacement at:
electricscooterparts.com
Posted on Aug 18, 2010
SOURCE:
I have a razor 24volt electric scooter it's charged but I turn the throttle the motor don't turn but will if I jump a wire from battery to motor
it could be the control box. check under the scooter. the photo shows everything needed to make it run. throttle to control box/box to motor/
May 31, 2015 | Electric Toys
My electric scooter hesitates, then goes, hesitates, then goes without letting up on the throttle
Going and Slowing is usually a problem with the throttle pot. They are often easy to fix yourself with a bit of WD40 once you have found out where the throttle pot is on your machine. Sometimes they have to be replaced, but fortunately the part is quite cheap. You didn't say what brand your scooter is, but Pride scooters are known for throttle pot problems.
Sep 16, 2014 | Electric Mobility Merits Electric...
I have a Rascal 200..was working fine..now after you go forward and let go of the throttle. ..it goes in reverse itself. .is there a throttle adjustment?
I had a similar problem on my Pride Legend scooter, it would
creep back in reverse if you let go of the throttle. The FWD/REV spring tensioned throttle pot inside was "off center"causing it to activate in reverse when it should have stayed put with the electric brake energized.
I had to replace the throttle pot assembly. Not sure if yours
is similar, but I would suspect it might be.
Jul 29, 2014 | Electric Mobility Rascal Scooters,...
I have two electric razor 175 and put new batteries in both of them. After fully charging them all i hear is a click everytime turn the throttle but nothing,, anyone that can help please help
Thank you for choosing FixYa, I will be helping you today :)
When using an electric scooter, it's always important to know that you must advance on the scooter manually, and during this action, only then can you turn the throttle. The engine on an electric scooter is not powerful enough to move a person by itself.
Hope this helps, thank you :)
Jul 03, 2011 | Razor E100 Electric Scooter
I have a gogo three wheeler and some times when i turn on the switch the scooter will not move, but when i turn the switch off and on two or three times it will work and some times the horn will start...
The go go controller has a controller which will give you a specific beep code to indicate the problem with your scooter. From what you are describing, it seems that the throttle potentiometer is out of neutral at start-up. The controller needs to electrically sense the throttle pot is in neutral (center of left and right) to start. By turning the scooter on and off you are jiggling the pot enough to get it to zero out(go to neutral).
Please get back to me with the exact model of the go go and with the exact number of beeps in the error code and I will be able to diagnose the problem in a more definitive way.
The most common error codes involve the throttle pot out of neutral at start-up and the brake freewheel lever is in freewheel.
You can see if the throttle pot is out of neutral by moving it slightly in either direction with one hand and turning the scooter off and on with the other hand. If the scooter works by this slight adjustment of the pot, then this part needs to be replaced. Hope this helps.
Jan 30, 2011 | Electric Mobility 3 Wheel Motorized...
Hey guys, I turned the throttle and i heard a click. And now the throttle doesnt accelerate, and the throttle doesnt even turn properly now.
sufi you will need to replace the speed control pot. Contact Pride @1-800-800-8586 ask for scooter tech support and explain your problem and ask about ordering a new pot hope this helps
Jan 23, 2011 | Electric Mobility Pride Electric Scooter...
Will not go. ohm wiring all good, batteries are good, checked fusses good, replaced throttle pot assembly, replaced controller.checked motor with 24 volts it works.got scooter to move by playing with...
me tool time you checked or changed about everything but did you check the electric brake. Sounds like the brake is not working or is working intermittentaly. The controller needs to get the right reading from the brake or the scooter will not go and when you release the throttle the brake should engage immediately. I can't give you a well thats the answer but you should at least ohm out the brake. If you can call rascal Company on Monday and ask for tech support they can give you what the reading should be Hope this helps
Sep 18, 2010 | Electric Mobility Health & Beauty
When i try to drive my E100 scooter it doesnt go but when i press on the light turns on and i checked the wires its all there any help please???
have you tried to push the scooter like a normal non-electric scooter then while moving twisting the throttle? If not, then i dont know what to tell you except to get a new one.
May 01, 2010 | Razor E100 Electric Scooter by
Electrical issues for a schwinn SW-4007-BL
Hi, These are both cables and it sure sounds like they are reversed. If you turn the throttle and try to push it is the wheel stopped? Check the cables on both ends to make sure they are routed to the correct function on your scooter. Good Luck, Hope this Fixsya!
Feb 22, 2009 | Electronics - Others
Razor E100 Electric Scooter Logo
494 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
