Question about HTC G1
Other than the G1 and Android appearing when my phone powers up, the screen stays blank. any ideas on what may be wrong?
    New Friend:
  • 66 Answers
Easy i just figured it out with my g1 with the same problem. The solution is this: Try taking out the battery put it back in. press and hold the power+home butto. a screen will show then press the power and home button agian. It will then give you some choices, choose wipe out your memory to factory settings and it should work after.
Posted on Apr 12, 2010
SOURCE:
My G1 Android will come on and show T-Mobile G1 then Android will come up but then the screen is blank? What can I do?
the best solution is to hard reset, follow the instructions bellow
1. Turn the G1 off. If it's frozen on, take the battery out and put it back in the unit.
2. Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.
Now to wipe the device clean:
3. Press Alt+L.
4. Press Alt+W for a factory reset.
5. Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
Mar 10, 2011 | HTC G1
How to unlock android G1 T-mobile powered by
you can unlock it by using the patten that you set or by entering the default pin
Apr 10, 2010 | T-Mobile G1 Android HTC Google Smartphone...
Phone not loading g1
You may need to wipe the factory setting. To do so, Turn Off the cellphone, now keep on holding the Home button and turn on the cellphone. It go to the recovery console, now select WIPE or press the short keys mentioned over there and restart cellphone.
Note: You will not loose any data but you may need to resign to google and also may need to install some application.
Thanks and regards,
Anil.B.R
Apr 09, 2010 | Google Android
Phone won't power up
try conecting another battery and than try it again refer to the user mannual comes along with the set
Apr 08, 2010 | HTC G1
My phone battery got completely dead,when i charged it i put it on and saw the welcome g1 tmobile and android after which it stays blank.so i dont know whats going on?please i need help
The battery needs to be revived when it is completely drained or when it is dead because the phone will not be able to charge it. For instructions on how to revive battery, check it here.
Apr 06, 2010 | HTC G1 Smartphone
Phone doesnt come on completely
Hi i have htc g1 mobile and i have a problem with the start-up when I tried to turn on the mobile the first logo was T.Mobile G1 and than it turned on to the second logo androd.after those two logo a blank screen came and near the battery it came warm and on the screen nothing happens.
When i turn on phone after android logo appears screen turns blank and phone will not turn off you have to take battery out
Try getting into recovery mode. Hold down home and press power. Keep holding home down while the phone boots. Can you get into recovery mode? You can just pull the battery after testing this.
You can also try holding "menu" while booting. This should put you in "safe" mode. If this works, then use the settings menu to do a factory reset and reboot.
Feb 26, 2010 | HTC G1 Smartphone
I dropped my g1and its stuck at a blank white screen......
the problem is that your chip is probably cracked and it is not allowing your screen to show up
Oct 06, 2009 | HTC G1 Smartphone
My g1 has a blank white screen screen locked
I dropped my G1, picked it up and it was fine went home a few hours later starting going through my apps it started running weird then it shut off...I took the battery out and put it back in when i did that it vibrated telling me there was life in the battery but the screen stayed blank no G1 intro no android nothing...then screen is not black but a grayish white depending the angle you hold the phone at. I called my carrier we did the reset nothing happened its still stuck at the blank screen? Any help with this?
Sep 25, 2009 | HTC G1 Smartphone
HTC G1 Logo
196 people viewed this question
Top HTC Computers & Internet Experts
robert roberts
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
