Two-cycle engines use a mixture of oil and fuel to power and lubricate the engine. Homelite blower engines use a ratio of 50 parts gasoline to 1 part two-cycle engine oil. Two-cycle engine oil is commonly sold in 2.6-ounce containers; add it to 1 gallon of gas to achieve the 50:1 ratio. Two-cycle engine oil for outboard motors is not compatible with Homelite blowers.Use premium fuel,the blower,weedeater,etc. will last much longer!
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular. RatioGAS:OILUNITED STATESOIL per 1 U.S. GALLON Gasoline
(128 oz.)*INTERNATIONALOIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)*INTERNATIONALOIL per 1 LITER Gasoline
(metric)
32:1
4 oz.
5 oz.
31.25 mL
40:1
3.2 oz.
4 oz.
25 mL
50:1
2.6 oz.
3.2 oz.
20 mL
Yes they will use the same mixture, it doesn't matter on the size of the engine. I would recommend using a 50:1 ratio. That equals out to 2.6 oz of oil per gallon of gasoline. Hope this helps, Daniel.
40 to 1 is most common. The safe thing to do is buy the oil and mix per the instructions on the oil. Not all oils mix the same. Use the oil recommendation on the bottle.
Not true. It is important to read the package and fuel/oil mixture ratio ie: 40:1, 50:1, 32:1, as long as the mixtures are the same, you can use one tank for all of the 40:1 tools, one can for all the 50:1 mixtures, one can for all the 32:1 mixtures. essentially all the 2 stroke oils are the same, the numbers just designate parts of oil(quantity) to parts of gas.
