You can copy these tracks back onto your computer, delete them off your MP3 player. Rename each track to the song name and then copy them back onto the MP3 player
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable * Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu. . Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
As far as why it's stopping it could be several things; there could be a problem with the track itself being corrupted or, depending on where you got the tracks, they could be protected with Digital Rights Management. The memory in the player could also be corrupt as well. I would start with reformatting the memory in the player to correct any potential corruption there might be. Below are three links that will answer both of your questions. Always make sure you properly disconnect the player from your computer to reduce the risk of corrupting the memory and causing these types of problems.
Format http://digiblue.com/customer-service/faqs/disney/mixmax/06.html
Select Recently Added, Artists, Albums, Songs, Genres, My Top Rated, Playlists, Podcasts, Audiobooks, or Recordings (Voice). - to view songs by album, artist, etc.
Or remove the track lisitng from the ID3 tag completely.
Manual is available online at RCA's website if it has been misplaced:
Turn shuffle off - p.16 of your manual - to get songs to play in sequential rather than random order.
For Audiobooks - p. 13 of manual:
Press M twice to enter Home menu. To play
music files, highlight “Music”(or "Audiobooks"
to play audible files) by pressing or .
Then press to advance.
The memory could be corrpt in the player. It some times happens so try reformatting the memory to clear it up. This will erase everything and then you can put your songs and
stuff back on it. Here's a link to the
manufacturers instructions on how to format the player.
In order to play your song you will need to try to transfer one track to that device...once you do that all the songs should acquire new licenses...you need to transfer tracks to your device once a month in order to play the songs...you should be able to play your purchased tracks....if not you might need to format the device inside WMP....then you need to check the licenses on your purchased tracks to make sure they dont have any restrictions...if you have any [email protected]
