Yamaha dv-c6760 we can only see the top half of our subtitles
Hello shell
I do not believe your problem is with the DVD player. It most likely is with your TV. What happens alot is the picture on a TV is set to a different aspect ratio(ie:4:3,16:9). and sometimes it stretches or zooms the picture, allowing part to be cut off the edge of the screen. This aspect ratio problem can have two causes now that I think of it. The TV or the DVD player. To determine and fix, follow these steps.
PART 1-determining problem-
1 Watch regular TV for awhile and get some infomercials(yes, you have to watch Billy Mayes) on the bottom and edges of the screen, are there words and 800 numbers cut off, if so, your problem is with the TV and skip now to part 2(not step 2)
2 If you can see the whole number and everything , determine if your TV auto adjusts or not. Switch to your DVD player and see if the screens seems to move(shrink or enlarge). If it does shrink or enlarge, your problem is with the DVD player and you can now proceed to part 2.
PART 2-solving problem-
1 By now, you have determined whether the problem is with your tv or dvd player. From this point on "it, it's will refer to whichever has the problem
2 Go into it's menu
3 search for "picture" "video" or "setup"
4 Search for "aspect ratio" or anything containing "4:3" "16:9" or the words "stretch" "zoom" or "widescreen"
5 Set to 4:3 (sometimes 4:3 has multiple options such as stretch, zoom, and normal, if so, select normal)
6 ***OPTIONAL*** If you want widescreen, select 16:9(again if multiple choices, choose normal)
7 Insert or select a DVD and test your subtitles
If this does not work, please post a comment and I will help you further.
Hope this helps and please don't forget to rate
-Chris
